- Thank you received: 49
rodw wrote:
I will check my wiring is as I documented later today.
I'm pretty sure the issue is water entering the torch tip and creating a circuit when we don't expect one with a water table. I know I have sometimes cleared a stuck probe (with a low off threshold) by either a Plasmac torch pulse to get air flowing or flicking the airflow switch on my plasma cutter.
The behaviour on a dry table now is exactly how it was when we first put this together.
