Just went through installing this for my machine and had a few issues that I worked through. Documenting them here in case anyone else needs it.
My biggest issue was after I wired everything up, I was getting 60 Hz influence on my THCAD-5 input IN+/-, which would oscillate ohmicsense.ohmic-volts from 0V to 24V when the ohmic cap and table were not connected. Removing the input plug to the THCAD-5 produced a stable ~0V output. The issue was that I did not have a ground connection to my table/frame, separate from the 24V PSU V- going to the table. As soon as I connected the "table" wire as diagramed in the manual to ground, it all went away and was stable at 0V. It seems obvious thinking about it now, but it took much longer than I'd like to admit to figure that out.
Secondly, I was having ohmicsense arc-on triggering because the output voltage was above 24.5 volts. I fixed this by tuning the PSU output to 24.00V after everything was connected. Previously I had set it @ 24.00V when it was not attached to anything. Now it does not trigger the arc-on bit. I have yet to cut with this and see what voltage is shown when the arc actually does short to the shield.
Lastly I could not get the ohmicsense.is-probing bit to go true while probing. In my hal file I changed
net plasmac:ohmic-enable => ohmicsense.is-probing (this was taken from the CNC plasma cutting primer doc)
to
net plasmac:ohmic-enable plasmac.ohmic-enable => ohmicsense.is-probing
Now ohmic "hypersensing" works great with the little dry-run testing that I have done.
Could this component be used for detecting tip-ups during X/Y movements? The arc would be off as it is moving between cuts, but it would be nice to have it be able to detect collisions. I have a mag breakaway mount, but this could be an extra safety. As I understand, this component is only active while plasmac is probing, so currently as is it may not be able to detect a jog collision. Thoughts?
