Hypersensing with THCAD - better way to do ohmic sensing
7 years 1 month ago #145904 by PCW
Yes, there's 7i96dpl.bit
6 years 10 months ago - 6 years 10 months ago #152773 by AgentWD40
So to be 100% clear an "isolated" psu means what exactly? Does that mean don't use the same 24v psu I'm using for the rest of my electronics?
What are the pros/cons of using the optional relay? Finally, any reason you have the relay on the AC side of the psu rather than something on the DC side, maintain isolation?
Last edit: 6 years 10 months ago by AgentWD40.
  • thefabricator03
  • New Member
  • New Member
6 years 10 months ago #152774 by thefabricator03
Replied by thefabricator03 on topic Hypersensing with THCAD - better way to do ohmic sensing
I have wired mine up but not set it up yet,
The isolated PSU means using a single PSU just for the Ohmic circuit.
Rod has mentioned to me in a email that the optional relay was not necessary after some testing he did.
6 years 10 months ago #152775 by bevins
More over, where is the second thcad?
  • thefabricator03
  • New Member
  • New Member
6 years 10 months ago #152776 by thefabricator03
bevins wrote: More over, where is the second thcad?
I mounted mine in my control cabinet vertically,
6 years 10 months ago - 6 years 10 months ago #152777 by rodw
There are various classes of power supplies and I've totally forgotten what the classes mean. But the one I used had isolation to 500 volts which coincides with the THCAD5's over voltage tolerance. eg. This 0.63 amp Meanwell. oceancontrols.com.au/PSM-0173.html (its only $20 or so).
This means is that both the THCAD5 and the DC side of the power supply are totally impervious to the arc voltage. So that means there is no need to turn off the AC power supply to protect anything. In fact, the component I wrote senses a full scale on the THCAD and enables an arc on pin which can only come on if some other voltage (like a plasma arc) is introduced into the sensing circuit.
PCW said leave the relay out and it took me a while before I was confident to do this until I really understood what an isolated power supply really meant.
When I first tested this, I just wired the power supply to another power point but when I wired it in properly I used a relay I had. It probably makes sense to drop this relay in an estop condition as the voltage is on the table and we want to isolate everything.
From memory, Islander261 had some unconfirmed third party reports that if the circuit was continuously left on, you could get some corrosion in the torch consumables on a water table so it was another reason I added the relay.
Last edit: 6 years 10 months ago by rodw.
Time to create page: 0.521 seconds
