The thcad2 replaces both the thcad 10 and thcad 5. The manual will tell you how to configure it. Go for a 200 volt range and you will be sweet for the 45XP
Personally, I would buy the cpc interface. There is a trick you can do with a short piece of fine wire inserted into the torch connector to permit CNC firing of the machine torch Search for it.
