My Newb Plasma Table Attempted Build
28 Apr 2020 22:59 #166028 by phillc54
Replied by phillc54 on topic My Newb Plasma Table Attempted Build
I use GT3 with a 16 tooth pulley on the motor and that is still a bit too coarse but it mostly works.
After looking a what Tom is doing a reduction is in order...
In hindsight I think GT2 would have been better.
The following user(s) said Thank You: tommylight, dvn4life1972
  • Moderator
  • Moderator
28 Apr 2020 23:35 #166034 by tommylight
Replied by tommylight on topic My Newb Plasma Table Attempted Build
16 tooth GT3 = 48mm per rev.
16 tooth GT2 = 32mm per rev.
I use the 16 tooth GT2 a lot on small engravers i build, directly driving the belt and microstepping set at 4, does the job perfectly.
The following user(s) said Thank You: phillc54, dvn4life1972
28 Apr 2020 23:42 #166037 by machinedude
Replied by machinedude on topic My Newb Plasma Table Attempted Build
the GT series of belts have the least amount of backlash from what i gathered. once you get into the pulley's that are small the walls get pretty thin and that part i was not real fond of. so if the belts can be bought with a 2 mm pitch that gives you a chance at a better pulley with some thickness to the bore walls.
if you do what Tom does you have all kinds of room to pick and choose a pulley that is more robust in size.
The following user(s) said Thank You: phillc54, tommylight, dvn4life1972
29 Apr 2020 02:02 #166048 by dvn4life1972
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
I actually happen to have 3 GT2 30 tooth pulleys and GT2 timing belt (2mm pitch). I accidentally ordered it months ago while I was working on the road and reordered the GT3 stuff. I was so tired all the time I was a little cross-eyed when I ordered it lol.
It would be simple enough to get the correct pullet and swap the belt out.
@Tommy I saw that Mazak in the background. Once upon a time I was the welder in a machine shop, and learned manual machining on a 80-30 WWII era Yamazaki engine lathe. It would still return to within .001" after all those years. Deadly if you weren't paying attention (no foot brake or safety stops).
Pat
29 Apr 2020 03:47 #166055 by machinedude
well at least your consistent 30 teeth with a 2 mm pitch is 60 mm of travel every rev of the motor :) same as what you have :)
  • Moderator
  • Moderator
29 Apr 2020 10:23 #166072 by tommylight
Yes, that is a MicroSlant 15, and is i still wonder how can something weighing in at 3.5 tons be named Micro, but hey, they are Japanese ! :)
Mine has two foot pedals but none of them are brakes, and an 11KW main servo motor, DC mind you.
29 Apr 2020 10:52 #166081 by rodw
Replied by rodw on topic My Newb Plasma Table Attempted Build
On the subject of reduction drives, Here is another one (3:1) on this thread.
forum.linuxcnc.org/30-cnc-machines/31509...pinion-drive?start=0
It was designed after I made a stuffup by building a direct drive Z axis so I had to replace a Nema 23 so I made it so it just bolted on in place of the stepper motor. Its peformed flawlesly. The great thing about mounting a motor on threaded posts like this is you can adjust alignment just by screwing the posts in and out.
The following user(s) said Thank You: dvn4life1972
29 Apr 2020 11:53 #166087 by dvn4life1972
Accidentally consistent :whistle:
I did just find 16T 2mm pitch pulleys on Amazon for $8/ea. Gonna order them up. One thing I really like about the feel of the GT3 belt vs GT2 is there is a lot more meat on the GT3. I suppose it really doesn't matter when using it in the belt on belt-rack configuration.
Pat
29 Apr 2020 11:55 #166088 by dvn4life1972
That's a sexy looking beast you built there Rod. Especially that Z axis, although it's all very nice indeed!
  • Moderator
  • Moderator
29 Apr 2020 12:27 #166090 by tommylight
That is way to much for those, they should be from 1.2 to 1.7$/ea.
www.ebay.com/sch/i.html?_from=R40&_trksi...+gt2+pulley&_sacat=0
or
www.amazon.com/WINSINN-Aluminum-Synchron...id=1588163183&sr=8-8
Just make sure the bore is what you need.
Time to create page: 0.916 seconds
