My Newb Plasma Table Attempted Build
- dvn4life1972
- Thank you received: 173
29 Apr 2020 13:10 #166091
by dvn4life1972
The ebay link is out of stock on 16T. I searched Amazon earlier and it didn't return any 16T sets like you found...much better set of 5 for same price as one I found lol. Gotta see if I have enough belt now to do the whole thing or of I need to order some with it.
Pat
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
That is way to much for those, they should be from 1.2 to 1.7$/ea.
I did just find 16T 2mm pitch pulleys on Amazon for $8/ea.
www.ebay.com/sch/i.html?_from=R40&_trksi...+gt2+pulley&_sacat=0
or
www.amazon.com/WINSINN-Aluminum-Synchron...id=1588163183&sr=8-8
Just make sure the bore is what you need.
Pat
- Thank you received: 7465
29 Apr 2020 13:16 #166092
Replied by tommylight on topic My Newb Plasma Table Attempted Build
www.amazon.com/ILS-Pulley-Timing-Printer...id=1588166094&sr=8-3
2m + 2 pulleys
www.amazon.com/Timing-Pulley-Teeth-Width...d=1588166027&sr=8-32
5m 10mm wide + 2 pulleys
2m + 2 pulleys
The following user(s) said Thank You: dvn4life1972
- dvn4life1972
29 Apr 2020 13:30 #166093
by dvn4life1972
1/4" bore (6.35mm). Still that 1st Amazon link you posted for a 5-pack will work fine. I found my belt in the garage...20ft, and I'll need 10ft more, so I'll order a 5 meter roll of the super cheap stuff and use it in the track as the rack. The belt I already have is Gates, I'll use that as the actual drive belt.
Pat
Pat
- Thank you received: 4141
29 Apr 2020 20:58 #166146
Thanks, it only took 3 months in my spare time to design and build...
Replied by rodw on topic My Newb Plasma Table Attempted Build
That's a sexy looking beast you built there Rod. Especially that Z axis, although it's all very nice indeed!
- dvn4life1972
30 Apr 2020 23:34 #166262
by dvn4life1972
The whole machine, or just the Z?
- dvn4life1972
01 May 2020 00:08 #166266
by dvn4life1972
I'm basically running down a list of stuff to do so I can then progress into plasmac.
Had a hiccup with the float switch, got that all squared away and got my torch holder put together. I'm not real sure how to test touchoff, I have no idea how or where to get g code files to test the base machine.
It does do 1200in/min without crashing. I reduced that limit to 900in/min. And I don't see the need for that much, to be honest. Sure am glad it stopped softly every time
Pat
Pat
01 May 2020 00:37 #166267
The Z axis complete and Y motor assembly. Making the gantry to mount it to only took a day or so.
01 May 2020 04:11 #166274
There are some example gcode files deployed with plasmac. A lot of people cut the Plasmac Spanner
github.com/LinuxCNC/linuxcnc/tree/master/nc_files/plasmac
Pat
- dvn4life1972
01 May 2020 14:50 #166326
by dvn4life1972
Thanks Rod. I was going strictly by the plasmac guide, which emphatically says to have a good base machine (no crashes, limits good, no plasma connections, and able to run some gcode). So do you mean I should be ok sans running some gcode, all other things being good and well?
Pat
Pat
01 May 2020 20:21 #166361
Try it, it should work as PLasmac does all its magic without touching gcode . But there is other sample code published as part of Linuxcnc.
BUt I would recommend that you learn enough about Gcode to draw a square in the air. That may teach you a thing or two about G64 offsets before you get going...
Pat
Time to create page: 1.662 seconds
