how to makeTHCAD10 work with pilot arc plasma
- jay1st
- Thank you received: 17
13 May 2020 11:43 #167640
by jay1st
Replied by jay1st on topic ARC OK signal to activate IO pin
mine is like the 1st picture, less the pilot arc switch, on this machine it's always connected
that is why the thcad does not work, always getting the same value what ever the distance.
i'm not saying this is the solution but it might be part of it
- Thank you received: 7478
13 May 2020 13:16 #167647
Picture 2 is like yours.
Replied by tommylight on topic ARC OK signal to activate IO pin
Not really, yours does not have a separate shield.mine is like the 1st picture,
The following user(s) said Thank You: jay1st
- jay1st
14 May 2020 07:30 - 14 May 2020 07:31 #167706
by jay1st
oh yeah, i meant i'll make it like the 1st picture, good to point it out
if i have time i'll give a try this afternoon
Last edit: 14 May 2020 07:31 by jay1st.
- jay1st
14 May 2020 14:55 #167749
by jay1st
After digging in the HAL METER signals in found the PLASMAC:ARC-OK-OUT
So i added in machine_connections.HAL
"net plasmac:arc-ok-out => hm2_7i96.0.ssr.00.out-01"
My relay is getting activated only when i get the arc ok green light.
Time to connect it to the pilot arc return !!
- jay1st
15 May 2020 19:42 #167888
by jay1st
THC works !!!
Some minor problems still, but hte THC works now, i can cut on a 45deg angle no problem
Minor porblems are :
1_ need to add a delay between the ARC OK OUT signal and the ativation of the output SSR on the 7i96 so the arc has time to "dwell"
2_ cant use a "not" for piloting the SSR output so had use a mickey mouse combination of relays to make an NC relay (as i only have NO relays), but now i have big ass relay for the pilot arc.
15 May 2020 19:54 #167889
Nice !
- jay1st
15 May 2020 20:16 #167890
by jay1st
I'm even thinking of using the pilot return from the torch as a ohmic sensor now that it can be disconnected !
Btw i used a motorbike starter relay, it's beefy enough to handle the amps i think.
- jay1st
18 May 2020 06:45 #168127
by jay1st
Having troubles setting up the correct timer for the torch to initiate the arc, so i am activting the relay to cut the pilot arc by using
net plasmac:thc-active => hm2_7i96.0.ssr.00.out-01
and it works perfect as the THC activation delay is user defined
- jay1st
19 May 2020 07:17 - 25 May 2020 09:04 #168233
by jay1st
Replied by jay1st on topic how to makeTHCAD10 work with pilot arc plasma
Changed the title of the topic as it might help others who are beginning with a cheap chinesium plasma cutter with HF and pilot arc
Last edit: 25 May 2020 09:04 by jay1st.
Time to create page: 0.106 seconds
