Ohmic sensing, what's best to use ?
6 years 5 months ago #169085 by rodw
Replied by rodw on topic Ohmic sensing, what's best to use ?
jay1st wrote:
rodw wrote: That depends. You have no idea how hard it was coming up with it! Be sure to learn how to use halcompile and write your own components. A lot of fun and Linuxcnc's best kept secret! I love it...
That is where i lack comptency, coding and understanding the codes !
I can do some stuff with an arduino, but C and Py is too much for me, i need to grasp how the HAL system works and so on...
If you are coding an Arduino Sketch, you are programming in C. Think of the LCNC servo thread as being the loop() function in Arduino and a component as being a function called from the loop() and you are in business.
The following user(s) said Thank You: jay1st
6 years 5 months ago #169088 by phillc54
Replied by phillc54 on topic Ohmic sensing, what's best to use ?
rodw wrote: [If you are coding an Arduino Sketch, you are programming in C. Think of the LCNC servo thread as being the loop() function in Arduino and a component as being a function called from the loop() and you are in business.
That is a neat way of looking at it.
6 years 5 months ago #169090 by rodw
Well technically, the servo thread is an Interrupt Service Routine (ISR) attached to the timer interrupt so it would be a timer interrupt in Arduino speak... If you have not used interrupts (both timers and hardware) with your Arduino scripts you have not lived!. Hardware is great to read encoders and timers interrupts are great for stepper step generators.
6 years 5 months ago #169091 by jay1st
Replied by jay1st on topic Ohmic sensing, what's best to use ?
here is simple primer quite interesting to read about capacitive sensing / frequency
ssudl.solent.ac.uk/id/eprint/3497/1/Test results for a capacitance-based corrosion sensor - BINDT 10-10-2016.pdf
6 years 5 months ago #169093 by phillc54
I haven't done any interrupt stuff on an Arduino. In an earlier life if I needed that sort of thing I used 8748h/9h written in assembly code.
6 years 5 months ago #169095 by rodw
phillc54 wrote: I haven't done any interrupt stuff on an Arduino. In an earlier life if I needed that sort of thing I used 8748h/9h written in assembly code.
Its a long time since I wrote assembly. C does it all for you really!
Time to create page: 0.530 seconds
