- Thank you received: 17
Ohmic sensing, what's best to use ?
- jay1st
6 years 5 months ago #169098
by jay1st
Replied by jay1st on topic Ohmic sensing, what's best to use ?
Interrupts in arduino are very usefull and keep things tidy and speedy when set up correctly
Ahh ok that's why on some "services" in the HAL files it starts with Servothred
- Thank you received: 4153
6 years 5 months ago - 6 years 5 months ago #169105
Replied by rodw on topic Ohmic sensing, what's best to use ?
So just have a look at the source of some of the components here
github.com/LinuxCNC/linuxcnc/tree/master/src/hal/components
So all you need to do is to type "halcompile --install mycomp.comp" to compile and install.
If you have not compiled LCNC from source, I think you need to use sudo but I've never ever run linuxcnc other than compiled from source...
Last edit: 6 years 5 months ago by rodw.
The following user(s) said Thank You: jay1st
- Thank you received: 7491
6 years 5 months ago #169106
ESP32 can do much more, on two cores at once.
A few days back i built an RPM counter with ESP32, oled, own battery and charger, so i just had to slap an infrared sensor from an old photocopier and do some coding using interrupts and internal timers. It is bloody fast as in my moment of wisdom i removed all delays.
Replied by tommylight on topic Ohmic sensing, what's best to use ?
Arduino Uno and Nano can do up to 10 or 20 KHz when not using interrupts, but can do nearly 1MHz when using them.phillc54 wrote: I haven't done any interrupt stuff on an Arduino. In an earlier life if I needed that sort of thing I used 8748h/9h written in assembly code.
Time to create page: 0.285 seconds
