Esab Ultrarex UXD-P2000 Upgrade Project
03 Jun 2020 22:42 #170039 by Esaber
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Ok I will check with thim and see what he can come up with.
I thought about putting the mini-atx board along with the mesa boards and the thcad and everyhting in the same box, just like the esab control box. The mini-atx board is 17mm by 17mm. Not sure that's a good idea.
03 Jun 2020 22:48 #170041 by tommylight
Replied by tommylight on topic Esab Ultrarex UXD-P2000 Upgrade Project
I WANT ONE ! NOW !
170x170mm, and yes you can put it in the same box, i know i did.
03 Jun 2020 23:01 #170042 by Esaber
Good catch. 17cmx17cm :-)
Will probably send the order to eusurplus this weekend.
I installed the linuxcnc in a virtual machine to see what it looks like.
03 Jun 2020 23:22 #170046 by Esaber
Thank you Tommy for your help and Rod for your ideas and support.
The shopping list step is done. Let's see how we fare on the next step :-)
03 Jun 2020 23:52 #170050 by tommylight
You are welcomed, always.
04 Jun 2020 06:13 #170073 by rodw
Replied by rodw on topic Esab Ultrarex UXD-P2000 Upgrade Project
I hoped you worked out that 57 euro was for 5 relays, not 1!
04 Jun 2020 08:02 #170077 by Esaber
Yes for 5 :-)
Not sure why it's 18$ by your side and 68€ (including VAT) over here !
04 Jun 2020 08:05 #170078 by rodw
Yes for 5 :-)
Its $18 x 5 here so about $100
04 Jun 2020 10:42 #170092 by Esaber
Okeeeyyy I see !
So that's cheaper over here then !
It's 68€ for a pack of 4 :-)
04 Jun 2020 13:34 - 04 Jun 2020 13:34 #170095 by Esaber
Mesa's best kept secret is the little strip of bus bar shown here to the right of the 7i96. 2 banks x 12 common connectors but eusurplus might not stock them. Saves a lot of space. 1 bank for+24v and 1 bank for -24v field power.
I asked eusurplus about the strip. They don't stock them. They recommened Legrand 04854 alternative.
What do you think? (11 euros)
www.amazon.fr/Legrand-LEG04854-Bornier-r...nexion/dp/B00CMNNDXO
Last edit: 04 Jun 2020 13:34 by Esaber.
Time to create page: 1.330 seconds
