Motor wire connections
- txtrone
- Thank you received: 106
21 Jan 2021 18:13 #196123
by txtrone
Motor wire connections was created by txtrone
Would I have issues if I were to connect the wires (coming from the stepper drives) to the motors using a terminal block at/near the motor?
I am in the process of upgrading the wire from my steppers to my motors. The motors I have came with 25' 4C tails on them. The four conductors in the cable were crimp spliced together on then covered in one heat shrink.
Would it be ok to take the 'raw' wires coming from the motor, land them on a terminal block, and then land the larger homerun cable at that same block?
Thanks.
Thanks.
- Thank you received: 1480
21 Jan 2021 19:18 #196127
Replied by Todd Zuercher on topic Motor wire connections
I don't think so. I work with 3 machines that are set up that way.
The following user(s) said Thank You: txtrone
- txtrone
21 Jan 2021 19:23 #196130
by txtrone
Is there anything special about the terminal blocks on the machines you use? Are they enclosed? Just curious.
Thanks!
Replied by txtrone on topic Motor wire connections
Thanks!
21 Jan 2021 19:33 #196136
Nope, nothing special, just a row of screw terminals in a plastic junction box.
- Thank you received: 4151
21 Jan 2021 19:41 #196138
Replied by rodw on topic Motor wire connections
- txtrone
21 Jan 2021 19:47 #196139
by txtrone
Where the wires come into the socket, mounted on the angle, did you use heat shrink?
I used GX16 aviation microphone connectors so the motor could be removed easily. On some motors, I used a small piece of aluminium angle secured with the motor mounting bolts to hold the panel mount socket.
21 Jan 2021 19:55 #196141
Yes, sent me nuts doing that! I think I shrink wrapped each wire, then put a large piece around the whole cable. In some exposed areas, I covered the bare motor wires with some of that nylon mesh cable cover.
21 Jan 2021 20:06 #196142
Also, don't connect the cable shield to anything at the motor end.
It was a bit extreme possibly, but at the control box end, I used 5 pin connectors which allowed the shield to be passed inside the control box. I used the same type of cable inside the control box. This let me connect the shield to frame ground (the case) right at the stepper controller. This was pretty handy when I upgraded to the Lam drivers which had a connector for the cable shield.
At the controller, I added a normal spade connector to the cable shield , folded it back and secured it with shrinkwrap for a nice neat, easy to work with finish
- txtrone
21 Jan 2021 21:01 #196146
by txtrone
- Thank you received: 7488
21 Jan 2021 22:10 #196157
Replied by tommylight on topic Motor wire connections
Same here.Nope, nothing special, just a row of screw terminals in a plastic junction box.
Time to create page: 0.717 seconds
