Motor wire connections
- txtrone
- Thank you received: 106
21 Jan 2021 22:11 #196158
by txtrone
Replied by txtrone on topic Motor wire connections
Thanks!
22 Jan 2021 12:51 #196211
Replied by andypugh on topic Motor wire connections
I have done this a number of ways.
One way is to cut the wires to different lengths, solder splice them and cover in a single piece of heat-shrink, relying on the length offset to insulate phase-to-phase.
The stagger also keeps the splice narrower.
I used this when I got a bit carried-away with some flexible conduit:
photos.app.goo.gl/rJcXqjAnvXh7q2RQ8
I took a more pragmatic approach more recently:
www.thingiverse.com/thing:3515010
I like Neutrik SpeakON connectors for connecting motors.
The following user(s) said Thank You: txtrone
- txtrone
22 Jan 2021 13:13 #196221
by txtrone
I like the thingsverse tidy housing, Can those be purchased? Or did you make your own?
22 Jan 2021 13:40 #196228
It's my design, published for use by anyone with a 3D printer.
You can arrange to have them made commercially via the Thingiverse site, or just download the files and pass them on to someone you know with a 3D printer. (I make no money either way, so have no preference)
There are other designs on there too. I designed mine to be especially compact.
- txtrone
22 Jan 2021 13:49 #196229
by txtrone
Those are slick, I may have to find order some through Thingsverse. Thanks for sharing!
- kelargo
11 Jul 2021 17:52 #214304
by kelargo
Replied by kelargo on topic Motor wire connections
thanks, I like this idea.
Time to create page: 0.109 seconds
