- Hardware & Machines
- CNC Machines
- Plasma & Laser
- Pierce height would exceed Z axis maximum limit while ohmic probing
- bevins
- Thank you received: 338
18 Apr 2021 19:58 #206330
by bevins
OK, no lead outs it is. Can you delete my valid ark lost post?
Replied by bevins on topic Pierce height would exceed Z axis maximum limit while ohmic probing
If at all possible, no lead outs on plasma cutting.
By the time the machine reaches the end of a cut the part has already fallen or there is no material left as it was cut already at the start, so avoiding lead outs is a god habit.
And yes, water can cause ohmic issues, hence the ohmic is never used on water tables, but somehow Rod, Phill, Snowwy and some others here made it work reliably using PCW and Mesa THCAD.
- Thank you received: 7488
18 Apr 2021 20:06 #206332
Replied by tommylight on topic Pierce height would exceed Z axis maximum limit while ohmic probing
Done. Thank you.Can you delete my valid ark lost post?
The following user(s) said Thank You: bevins
- Thank you received: 4151
18 Apr 2021 20:40 #206334
Actually Islander261 got Phill to add the torch pulse button so he could get the air flowing before his first pierce to help keep the water out. He also got Phill to add the ohmic test button so he could check if there was any short in the torch tip (either water or other rubbish). So that was his starting procedure, check for shorts, get air flowing, then run his job.
Replied by rodw on topic Pierce height would exceed Z axis maximum limit while ohmic probing
18 Apr 2021 21:44 #206340
I wrote "using PCW..."
Sorry PCW.
Sorry PCW.
- bevins
19 Apr 2021 16:10 #206407
by bevins
Thanks Tommy and rodw for your help. Greatly appreciated.
As for phil and snowy, great work and thanks for the help.
I think it is under control now.
Just a few things to go over. Mainly THC, which is working but I don't know how good. Have to figure out best way to test.
19 Apr 2021 17:57 #206434
Get a 30cm long plate and a piece of 40x40 to 60x60mm tube, put the tube on one side so the plate is sloped, use the "single cut" feature in QTPlasmaC and watch it raise of fall!
20 Apr 2021 09:27 #206513
If it makes you feel better, l could not probe today! It ended up being a loose mains wire on the Ohmic power supply. Its been 6 weeks since I cut something cos I have been on a 2kg lifting limit after gall bladder surgery.
One thing I did notice was a build up of oily grease and crap under the ohmic clip so its something to watch out for.
20 Apr 2021 09:54 #206516
@Rod,
Hope you get well soon, i have to move 400KG table so waiting for you to help !
20 Apr 2021 10:02 #206517
The last person who asked for my help went to Jail before I got there so be careful what you ask for!
I'm all good now. Left my car parked at work and went to hospital for a week to have my gall bladder out then they said no lifting for 6 weeks. I tried to be good!
@Rod,
20 Apr 2021 10:30 #206518
Oh cr@p! Never mind, i will cut it into small pieces and reassemble it later!The last person who asked for my help went to Jail before I got there so be careful what you ask for!
- CNC Machines
- Plasma & Laser
Time to create page: 0.447 seconds
