New Plasma build in OZ
- 34by151
- Thank you received: 16
16 Jul 2021 09:51 #215013
by 34by151
Replied by 34by151 on topic New Plasma build in OZ
Waiting on prices from TEA, Industrial dynamics and statewide
Sunstate came in at
The 20 mm Linear rail, x 37000mm long $986.00 +gst each
Linear Blocks to suit Rail, $136.00 +gst each
Sunstate came in at
- 34by151
16 Jul 2021 09:55 #215015
by 34by151
Ive just really been working on the table and Y rails setup.
The Gantry and Riser plate is just there to tie it together for now.
Once I put all the hardware into the table ill start on the drive for the Y and then getting the X znd Z details in.
- Thank you received: 4149
19 Jul 2021 20:47 #215337
So we welded a M30 x 2mm nut on the inside of the bottom end cap for the leg and used M30 x 20 threaded rod for the adjustable leg. The base is 100mm dia 10mm thick lasercut steel. I turned the threaded rod down for 5mm so it was a press fit into the base and plug welded it from the bottom. a M30 half nut as a lock nut and its very solid.
Replied by rodw on topic New Plasma build in OZ
I tried hard to get feet and casters to coexist but was never happy the arrangement would be rigid. So the casters come off to fit the feet.Hat you cant see in the pic is the mounting plate. Im guessingyour looking at the adjuster bolt that lowers the wheel. Thes normall sit on the pad and the wheel is only down to move it.
- 34by151
20 Jul 2021 01:09 #215357
by 34by151
I will go with the leveling casters and if they work out great otherwise it's not hard to remove them and put in feet.
Probllay have some time to do some design work today.
Need to make some decisions on the x axis stepper mount.
- 34by151
20 Jul 2021 06:41 #215385
by 34by151
Been doing some work on the ganrty design.
Opinions on mounting the stepper locations for the X and Y
Im looking at mounting the steppers at the end of the slides.
Seems to make sense for the Y lowering the gantry weight.
Not sure if it worth doing the same on the X axis.
What are everyones thoughts?
- 34by151
23 Jul 2021 09:04 #215655
by 34by151
Statewide Prices
4000mm rails $700 each
Carrages $85.50 each
Scraper kit per carrage $22.50
prices ex tax
prices ex tax
- Thank you received: 7478
23 Jul 2021 09:10 #215656
Replied by tommylight on topic New Plasma build in OZ
Steppers should be mounted as close to the rails/carriages as possible, keeps the mass near refference point, the overall result is less vibration.
- 34by151
23 Jul 2021 10:55 #215669
by 34by151
Thnaks for that.
So mounting the Y stepers on the carrage using a single belt fixed at both ends is better then a looped belt with the stepper on one end.
In other words the higher overall weight of the garnty is less of a concern than the vibration in the belt.
23 Jul 2021 11:25 #215673
Using reduction would be nice, direct driving the belt is also usable with microstepping drives.
Always and yes.
23 Jul 2021 12:04 #215679
I just checked Industrial Dynamics, they quoted me $531.95 for 3 m of HGR25 in June
Time to create page: 0.138 seconds
