Bevel for 1.2mm Stainless Steel
25 Jul 2021 02:21 #215835 by shizyo
Replied by shizyo on topic Bevel for 1.2mm Stainless Steel
It doesn't show the amber error light but sometimes I will see 2 green lights, 1 in the middle and 1 at the top or the bottom indicating the air pressure is a little high or a little bit low. Definitely I will put in a new regulator at the back of the plasma cutter to see how it goes. If you have any other ideas to try, please let me know.
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
25 Jul 2021 02:44 #215837 by thefabricator03
Replied by thefabricator03 on topic Bevel for 1.2mm Stainless Steel
I will do. Read through your user manual for the 45 unit and see what the machines should do if the pressure is too high or low.
On my 125 amp unit I get error codes 0-12-1 for too low air pressure and I have had 0-12-2 for too high air pressure.
Time to create page: 0.070 seconds
