My foldable plasma table
- Ekholm
- Thank you received: 12
26 Jul 2021 06:19 - 26 Jul 2021 06:31 #215929
by Ekholm
My foldable plasma table was created by Ekholm
Hi! I´m building a foldable plasma table and i have no prevoius experience with motors or controllers.
I will try to post my journey as it develops.
My thougts with the build is that i have a verry small garage and i need to make my plasma small. So my work area is something like 1000x1000mm. I made the construction foldable to make it even smaller when storing,
I will enter qestions as they will come during the build. I have soon made all the mechanical build and will start with the electrical side of the build.
I have a cheap HF plasma that i will start with, but i'm pretty shore that i will upgrade to a pilot arc when i see that it works.
Because of the HF plasma i have isolated all linear units form the cutting table with plastic. All cables will be shealded to prevent the HF noise, but as i said , i´m prepared to buy a new plama with pilot arc
Last edit: 26 Jul 2021 06:31 by Ekholm. Reason: adding information
The following user(s) said Thank You: phillc54, tommylight
- Thank you received: 7465
26 Jul 2021 10:27 #215946
Replied by tommylight on topic My foldable plasma table
Neat!
- Ekholm
27 Jul 2021 04:03 #216013
by Ekholm
Replied by Ekholm on topic My foldable plasma table
I have bought some NPN sensors to use with my 7i96 board. Will it work? I read some where that you could use PNP and NPN, but I don’t understand the difference in wiring. These are the sensors that I bought. Planning to run those at lower voltage that specified (use the same power supply as for the 7i96 and hope that it will work)
- Thank you received: 4141
27 Jul 2021 05:21 #216016
Replied by rodw on topic My foldable plasma table
I made the same mistake. Use 24 v for field power and a 2.2k 1W pull up resistor (between the signal output and the +24 input/
The following user(s) said Thank You: Ekholm
- Ekholm
24 Aug 2021 18:49 #218632
by Ekholm
Hi! I hope that I will have some time to keep building soon. I was wondering which axis is which. I attached a picture. Is this correct.
Can I chose the homing sensors on X+ And y-
Do I need to have two limit switches if I have encoder, or should I add it to both sides.
- Thank you received: 5315
24 Aug 2021 19:47 #218639
Replied by PCW on topic My foldable plasma table
The 7I96 can work with NPN or PNP type sensors
For NPN type sensors:
7I96 input common (TB3 pin 12) --> +24V
prox negative common --> 24V common/GND
prox output --> 7I96 input (TB3 pins 1..11)
For PNP type sensors:
7I96 input common (TB3 pin12) --> 24V common/GND
prox positive supply --> +24V
24 Aug 2021 22:07 #218645
Just an example of X Y Z axes,
carlpaton.github.io/2021/03/cnc-machine/
- Ekholm
30 Aug 2021 11:59 #219160
by Ekholm
A small video update. I hope that i´m finished with the mechanincal part, and shall now start with wiring.
The following user(s) said Thank You: tommylight, snowgoer540
30 Aug 2021 13:16 #219167
Nice !
- Ekholm
06 Sep 2021 10:48 #219750
by Ekholm
Hi PCW! Do i understand you correctly
Se attached picture. This is for my NPN sensor
Will this also work for my contact switch for height probing? Do i add a big resistor or how do i do so i don´t short the power supply?
Time to create page: 1.180 seconds
