Integrating a BCL-AMP capacitive sensor to LinuxCNC
8 months 2 weeks ago #343005 by PCW
If you do not, you will have a huge offset that would have to be compensated
by using a similar setpoint. If you use the 22900 offset, you will now have
a 0 to 1000 active range ( if scale = 1)
The following user(s) said Thank You: Nathan40
8 months 2 weeks ago #343007 by Nathan40
Thanks for the reply.
For the 930000, fake ohmic sensing are we expecting the voltage value to around 15500.
Please let me know
8 months 2 weeks ago #343008 by PCW
That entirely depends on your scaling.
On way to check is to monitor the "plasma_voltage"
 and determine the threshold  for the fake Ohmic sense point.
8 months 1 week ago #343344 by Nathan40
Thank you for your response. Please let me know if we can reduce the cut amps of qtplasmac. It is not allowing to reduce from 25. With a scale of 20 of pwmgen, its firing at 80% duty cycle.
7 months 6 days ago #344751 by Nathan40
Hi All,
The ohmic enable gets randomly triggered when laser is enabled. The wiring is as follows to the 7c81 board: 5v from bob , signal to 7c81 encoder pin direct, pins 3 and 4 to gnd of bob. Please help!
Time to create page: 0.359 seconds
