Integrating a BCL-AMP capacitive sensor to LinuxCNC
- Thank you received: 5325
15 Feb 2026 16:30 #343008
Replied by PCW on topic Integrating a BCL-AMP capacitive sensor to LinuxCNC
That entirely depends on your scaling.
On way to check is to monitor the "plasma_voltage"
and determine the threshold for the fake Ohmic sense point.
The following user(s) said Thank You: Nathan40
- Nathan40
23 Feb 2026 15:22 #343344
by Nathan40
Replied by Nathan40 on topic Integrating a BCL-AMP capacitive sensor to LinuxCNC
Thank you for your response. Please let me know if we can reduce the cut amps of qtplasmac. It is not allowing to reduce from 25. With a scale of 20 of pwmgen, its firing at 80% duty cycle.
- Nathan40
26 Mar 2026 03:55 #344751
by Nathan40
Hi All,
The ohmic enable gets randomly triggered when laser is enabled. The wiring is as follows to the 7c81 board: 5v from bob , signal to 7c81 encoder pin direct, pins 3 and 4 to gnd of bob. Please help!
Time to create page: 0.280 seconds
