Black Friday Deal got me :)
1 year 5 months ago #328064 by machinedude
i have actually learned quite a bit from this project to be honest. i have some big plans for this build. a conventional table and a rotary cutter have some very different needs, if all you need is to cut round tube then things can be kept fairly simple, but if you cross over into other profiles things can get quite involved. this project is one of those projects that take forever to get finished but once done you have something substantial.
1 year 5 months ago - 1 year 5 months ago #328196 by machinedude
add loaded forces to the mix and i just learned something else this weekend. always something with this project, it seems. 450lbs of force is no joke or 2000N for everyone over on the other side of the pond.
Last edit: 1 year 5 months ago by machinedude. Reason: fixed my metric conversion
1 year 5 months ago #328206 by tommylight
200N = ~20.3KG ???
450LBS = over 200KG = ~2000N
ASUS ROG Crosshair VIII Impact - AMD X570
1 year 5 months ago #328218 by machinedude
2000N i should have just let you convert it :) sorry i was going off of memory and should have added the extra 0 thanks for the catch on that.
1 year 5 months ago #328220 by tommylight
No worries at all, it has just become increasingly bad info all over the web, so at least here trying to keep info correct.
1 year 5 months ago #328223 by machinedude
i fixed everything so it all good information now.
Time to create page: 0.482 seconds
