Black Friday Deal got me :)
  • machinedude
  • machinedude's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Jun 2025 08:04 - 02 Jun 2025 22:24 #329497 by machinedude
Replied by machinedude on topic Black Friday Deal got me :)
i did some rework on the mounting for my air cylinders and have been getting stuff gathered and sorted for driving this chuck while i have been working on the clamping needs for soft jaws for this thing. i did some testing to see how good things will center and with out to much effort i looks like things will at least be within .015 off center at the worst 90 degrees from the air cylinders. centering and around .005 off in the line of the two air cylinders. so things look promising so far.
I'm not sure what would realistic since stock tubing is not going to be perfect to begin with but i have one last thing to try to see if i can get things in line better to get as good as i can get and produce repeatable results every time. If i can get within .005 of center all the way around i don't think it's going to get much better than that or at least on a repeatable level.
accurate clamping and centering will open up better options for programming a rotary, so this is my end game. i also think once you add a second chuck that will help quite a bit as well.
Last edit: 02 Jun 2025 22:24 by machinedude.
Time to create page: 0.158 seconds
