Black Friday Deal got me :)
- Daan96
- Thank you received: 7
20 Feb 2025 15:43 #322080
by Daan96
Replied by Daan96 on topic Black Friday Deal got me :)
This is the one I’m going to follow, I haven’t seen it before, but I started a similar idea in "show your stuff."
- machinedude
- Thank you received: 312
01 Mar 2025 10:30 #322915
by machinedude
Replied by machinedude on topic Black Friday Deal got me :)
i was not happy with the force to spin this thing but it seems the bigger you go the greater the torque needed based on some digging with manufacturer specs i found. i found these that i could buy over seas but they require 3.5 Nm of torque. i'm not sure if that is breakaway or running torque? i'm thinking it's breakaway but i am not sure at this point. if i can figure out a way to test this so i can get a feel for it i might be at a fork in the road moment and end up just biting the bullet and buying these is it seems better than what i was seeing with what i was doing. 3,5 Nm seems like a lot of torque needed?
- machinedude
01 Mar 2025 15:40 #322929
by machinedude
i have a question for anybody who does rotary plasma cutting. what kind of rpm range do you need on a rotary plasma system on the rotary axis? i'm checking into unions and these have a 100 rpm limit unless you upgrade the seals then i think they can do 300 rpm which is probably overkill. is 100 rpm enough or do i need a little extra. i'm guessing the part diameter factors in since the piece is rotating but i'm just looking for a general range of speed needed if anyone has a moment to reply.
thanks in advance
thanks in advance
- Thank you received: 7488
01 Mar 2025 16:02 #322932
Replied by tommylight on topic Black Friday Deal got me :)
1-3m/m should be enough for cutting, so depending on tube diameter adjust accordingly by multiplying that diameter with the PI value of 3.1415....
- machinedude
01 Mar 2025 17:07 #322944
by machinedude
i guessing the 1-3 m/m is m/min? metric conversions between units is not exactly my thing
but if that is the case 120ipm is the high side. so it looks like things move pretty slow. 1 inch tube would probably be on the small side and spin the fastest so that's around 38rpm give or take.
- machinedude
23 Mar 2025 11:26 #324647
by machinedude
my first attempt at a rotary union ended up being a bust. i was going to just eat the cost and buy these but something the manufacture said during a response made me pause on that idea. i was told a 2 Kw motor was the requirements to drive one of theirs. my plan was to drive two of these in series so a 4 Kw motor to do this seemed like a deal breaker. so i decided to take another attempt at one. i got tired of looking for a sealing solution from the manufactures that would work with common stock size and trying to find a certain type of seal in the size i needed. So i did what i had to and took matters into my own hands and designed my own and made a mold to cast them myself. so i will either get thing to work or go down swinging trying
- machinedude
10 Apr 2025 06:31 #326017
by machinedude
I'm working on a second version of a rotary union, i feel good about this one working but until it's built and tested it's all wishful thinking
I'm just going to make short videos as i go and post progress. it seems like it is an interesting topic, and it seems justified to spend the extra time on that end.
- machinedude
19 Apr 2025 07:23 #326666
by machinedude
small update moving forward with this.
19 Apr 2025 11:27 #326682
Music was nice!
- machinedude
21 Apr 2025 00:00 #326780
by machinedude
another update
The following user(s) said Thank You: tommylight, Clive S
Time to create page: 0.136 seconds
