Black Friday Deal got me :)
  • machinedude
  • machinedude's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Apr 2025 23:02 #327198 by machinedude
Replied by machinedude on topic Black Friday Deal got me :)
update again :)
  • machinedude
  • Platinum Member
  • Platinum Member
04 May 2025 07:50 #327658 by machinedude
Not too much going on this weekend the grandkids and kids got me sick so i have slept through most of it.
but it does work as intended. hopefully now that i have a physical assembly made it's starting to make sense as a whole a little more.
  • machinedude
  • Platinum Member
  • Platinum Member
04 May 2025 11:14 #327666 by machinedude
the more i think about this project the more it feels like a Rube Goldberg machine build :) But that's a good thing it creates innovation :) i think Rod pointed out an uncertainty about a tandem rotary axis but i am on to the why it makes sense thought process now, i think. i might be sick and not feel like doing physical work but my brain is in overdrive it seems.
07 May 2025 16:42 #327951 by CarterKraft
Replied by CarterKraft on topic Black Friday Deal got me :)
I bought that same Hynade 80amp cutter in October '23 and have been running it ever since on my homemade linuxcnc/mesa table, no complaints at all.
I did some research on the torch and found the manuals from Tecmo are the source of the torch or are excellent copies.
www.tecmo.it/wp-content/uploads/2023/02/2022-09-A-PT.pdf
I purchase torch consumables under their part numbers from ebay seller PlasmaDyn www.ebay.com/str/plasmadynplasmaweldingparts
Looking forward to this build.
  • machinedude
  • Platinum Member
  • Platinum Member
09 May 2025 13:09 #328064 by machinedude
i have actually learned quite a bit from this project to be honest. i have some big plans for this build. a conventional table and a rotary cutter have some very different needs, if all you need is to cut round tube then things can be kept fairly simple, but if you cross over into other profiles things can get quite involved. this project is one of those projects that take forever to get finished but once done you have something substantial.
  • machinedude
  • Platinum Member
  • Platinum Member
11 May 2025 11:55 - 11 May 2025 19:51 #328196 by machinedude
add loaded forces to the mix and i just learned something else this weekend. always something with this project, it seems. 450lbs of force is no joke or 2000N for everyone over on the other side of the pond.
Last edit: 11 May 2025 19:51 by machinedude. Reason: fixed my metric conversion
11 May 2025 17:33 #328206 by tommylight
Replied by tommylight on topic Black Friday Deal got me :)
200N = ~20.3KG ???
450LBS = over 200KG = ~2000N
  • machinedude
  • Platinum Member
  • Platinum Member
11 May 2025 19:48 #328218 by machinedude
2000N i should have just let you convert it :) sorry i was going off of memory and should have added the extra 0 thanks for the catch on that.
11 May 2025 19:52 #328220 by tommylight
No worries at all, it has just become increasingly bad info all over the web, so at least here trying to keep info correct.
  • machinedude
  • Platinum Member
  • Platinum Member
11 May 2025 20:00 #328223 by machinedude
i fixed everything so it all good information now.
Time to create page: 0.615 seconds
