- Hardware & Machines
- CNC Machines
- Plasma & Laser
- Laser Head Height Sensor – Looking for a Beta Tester
- phino
- prokopcio
- Thank you received: 26
CONVERTER SIMULATION
- prokopcio
So, I have a question:
Would anyone be willing to test the device?
I'm looking for someone with knowledge who will find the time to do so soon and share their honest observations here, especially the shortcomings.
New User Manual:
proma-elektronika.com/download/c2v_laser_sense_en.pdf
- Thank you received: 7488
I do not have access to laser cutter i can mess with, so i can not test it.
I would gladly test it as i did test your equipment before and i could not destroy it, on purpose, even reversing the power supply polarity did nothing! Utmost respect for that.
- prokopcio
- phino
The machine available for use right now uses a 1.5 kW laser, an Aerotech controller, and an optical height sensor, and it could be reconfigured to test your capacitive height sensor. If that is of use to you, please advise.
In any case, we're interested in this height sensor for possible use on upcoming projects, especially since our intention is to move towards LinuxCNC with future laser machines.
- prokopcio
As I mentioned, the sensor was developed for my own needs, but I would like it to be easy to use also in open-source control systems such as LinuxCNC.
Trying to use it at this stage in closed, good working solutions does not make sense.
I appreciate your willingness to support me, but at this point it is not a good idea.
- prokopcio
Are you still interested and would you have time to test the sensor?A test device would be great. What information do you need to get it to me?
If so, please contact me, preferably through the Proma-Elektronika contact page.
- phino
Understandable. I agree with the aim of validating the functionality of the sensor with open source controllers like LinuxCNC.Hi, Unfortunately, I have no experience with Aerotech.
To clarify, the suggestion was not to validate use with Aerotech controllers. The thought was just that it should be simple enough to configure the analog input/output to use the sensor with the existing system available. That would allow testing the sensor's functionality under different conditions, if that would be of use to you.
Looking forward to seeing tests of this sensor by others with LinuxCNC-based laser systems.
- prokopcio
It seems that I may not have fully understood what you expect and how you would like to test it.
- CNC Machines
- Plasma & Laser
