Cut Parameters
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
04 Jan 2020 02:47 #153948 by thefabricator03
Replied by thefabricator03 on topic Cut Parameters
No worries Phil - I will go into the workshop either this arvo or in the morning and I will send it though.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Jan 2020 03:46 #153954 by phillc54
Replied by phillc54 on topic Cut Parameters
Nearly done, one last question.
Should this "Pause At End" come into play if a user presses Pause or should the arc immediately extinguish?
04 Jan 2020 03:51 #153956 by rodw
Replied by rodw on topic Cut Parameters
I think during a cut you would not pause. Just turn it off. You might not have enough material left on a restart to get an ArcOK.
  • phillc54
  • Platinum Member
  • Platinum Member
04 Jan 2020 03:55 #153957 by phillc54
But Pause is an intrinsic part of LinuxCNC and I think we need to account for what happens if it is used.
Would you not Pause to do say a consumable change if you notice it during a cut?
04 Jan 2020 04:25 #153960 by rodw
But on a restart you will pause again for the pierce delay so you will be doubling up, causing big divots and probably not leaving enough material to get a valid ArcOK on the restart so you could ruin the job......
  • phillc54
  • Platinum Member
  • Platinum Member
04 Jan 2020 04:29 #153961 by phillc54
I read that as being that you would not press pause during a cut.
Is that what you meant or did you mean:
If you pause during a cut you would not activate the Pause At End timer, turn the torch off immediately.
  • thefabricator03
  • Visitor
  • Visitor
04 Jan 2020 04:50 #153962 by thefabricator03
If the user pauses the torch should stop - but if the part is being cut, the pause at the end would still be as per normal
  • phillc54
  • Platinum Member
  • Platinum Member
04 Jan 2020 04:53 #153963 by phillc54
Thanks Stefan, I think that is also what Rod means but I interpreted his post a bit differently.
04 Jan 2020 06:00 #153965 by rodw
Yes, thats what I meant
  • phillc54
  • Platinum Member
  • Platinum Member
04 Jan 2020 06:34 #153968 by phillc54
I have pushed this update.
