- Thank you received: 7491
That is another very nice feature. Thank you.phillc54 wrote: I have had a bit of a play with this suggestion from LuisGZ and have come up with this:
Basically you hit pause then the user button programmed for consumable change. It will go to the x/y position and after changing consumables, hit resume and it will return to the original position and begin a probe.
The X, Y and feedrate are all user programmable.
Comments welcome.
Probably could be done but not with the existing jog buttons which then leads to where to put them. It would be quite a bit of work.thefabricator03 wrote: Is it possible to be able to pause the machine, then be able to jog to any position and then un pause the machine and it will resume where it left off?
