Cut Path Not Following Gcode
- MakingStuff
- Thank you received: 14
There is a file called imperial_startup.ngc (or metric_startup.ngc) that sets G64 P0.04, it should have been G64 P 0.004. The metric version is correct at G64 P0.1
So once you make this fix I won't have to manually add it to each gcode file?
- phillc54
- Thank you received: 2100
Note: If you did a Buildbot installation you will need to edit it as the root user.
- islander261
- Thank you received: 216
While Phill does a great job of setting default operating conditions I will continue to set G64 to the correct values in my the G code preamble and at tool changes with my PP.
- phillc54
- Hakan
- Thank you received: 454
When hitting E-stop in linuxcnc, the G64 P setting is reset to default and one end up with round corners again.
It is a known bug github.com/LinuxCNC/linuxcnc/issues/177 and I just verified it is still there.
- OT-CNC
- Thank you received: 75
Thanks for the heads up. I didn't know that bug. Just to confirm, if it's listed in the ini RS274 startup code section it will be read as the default and behave correctly after estop. Correct? Reason I'm asking is I'm not loading the startup g code program that axis normally starts up with.
- Hakan
Easy to test with for example this snippet
G0X0Y0
G1X100F1000
G1Y20
G1X0One isn't supposed to know about every bug, but I happened to find it and tried to understand what is going on in the code but it would take more time than I currently could spend. I settled on adding a line "G64 P0.01" in the post processor I use.
- phillc54
Hakan, have you reported this on the LinuxCNC Github page.
- Hakan
- Aldenflorio
- Thank you received: 15
