Error after PlasmaC Upgrade
  • EW_CNC
  • EW_CNC's Avatar Topic Author
  • Premium Member
  • Premium Member
09 Nov 2019 18:14 #149999 by EW_CNC
Error after PlasmaC Upgrade was created by EW_CNC
This is my first time upgrading a working PlasmaC config.
I receive the attached error when I start LinuxCNC.
Then when I ok it, LinuxCNC opens (axis) and the user buttons are not fully visable.
So far everything else works good.
Do I have something missing?
EW
09 Nov 2019 22:08 - 09 Nov 2019 22:09 #150023 by phillc54
Replied by phillc54 on topic Error after PlasmaC Upgrade
Did you run the Configurator in upgrade mode?
Edit: If you have a Run In Place installation did you run make to rebuild it?
Last edit: 09 Nov 2019 22:09 by phillc54.
  • EW_CNC
  • Premium Member
  • Premium Member
09 Nov 2019 22:41 #150027 by EW_CNC
Replied by EW_CNC on topic Error after PlasmaC Upgrade
I ran the configurator and selected upgrade. From a terminal:
$ python /usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/configurator.py
From my understanding I do not have Run in Place, my linuxcnc file is user/linuxcnc/configs/. Am I correct?
10 Nov 2019 02:29 #150038 by phillc54
Run In Place means you did a git clone then built LinuxCNC, the other type is a package install from the BuildBot.
Both types have the same directory in the users home directory.
Could you post your .ini and .hal files please.
  • EW_CNC
  • Premium Member
  • Premium Member
10 Nov 2019 02:56 #150040 by EW_CNC
Attached the files:
File Name: linuxcnc_plasma.ini
File Size:9 KB
File Name: linuxcnc_plasma.hal
File Size:12 KB
File Name: linuxcnc_p...ions.hal
File Size:2 KB
File Name: plasmac.hal
File Size:3 KB
File Name: plasmac_config.hal
File Size:3 KB
File Name: plasmac_run.hal
File Size:2 KB
10 Nov 2019 04:16 #150041 by phillc54
Can you start LinuxCNC from a terminal and see if there are any errors as it is loading.
Sorry I am i bit slow responding but I am not getting any email notifications for some reason.
  • EW_CNC
  • Premium Member
  • Premium Member
11 Nov 2019 15:26 #150126 by EW_CNC
I started from terminal and it gave the same response.
Attached terminal startup:
File Name: Terminal_S...1-11.txt
File Size:3 KB
11 Nov 2019 22:03 #150158 by phillc54
For some reason it is not creating the plasmac_run.cut-type hal pin.
Could you open a terminal and get a directory list:
ls -al /home/eweaver/linuxcnc/configs/linuxcnc_plasma > dir.txt
and post the dir.txt file as well as a copy of plasmac_run.py from the above directory.
  • EW_CNC
  • Premium Member
  • Premium Member
11 Nov 2019 23:38 #150160 by EW_CNC
File Name: dir.txt
File Size:5 KB
File Name: plasmac_run.py
File Size:27 KB
11 Nov 2019 23:44 #150161 by phillc54
Can you load a GCode file after LinuxCNC loads without it giving that error?
Time to create page: 0.224 seconds
