multi use inputs
01 Dec 2019 21:59 #151705 by bright
multi use inputs was created by bright
I've found a way to use one input for both Z home and probe. is there a way to setup the Y0 home, Y1 home, and X home to be used for arc-ok, THC move-up and move-down inputs after homing is completed?
01 Dec 2019 22:08 #151706 by phillc54
Replied by phillc54 on topic multi use inputs
I would imagine that with a bit of HAL wizardry that would be possible. You could probably use some existing HAL components or even create your own.
Have a look at the HAL section here. linuxcnc.org/docs/devel/html/
03 Dec 2019 01:03 #151802 by andypugh
Replied by andypugh on topic multi use inputs
It doesn't matter if the home inputs are toggled once the machine is homed, so you can probably leave those unconnected.
Then use and2 with the pin input and an axis .is-homed pin so that the output is only triggered when the pin is true _and_ the machine is homed.
Though, it is common to combine limit and home switches. Would doing that help?
Time to create page: 0.183 seconds
