PlasmaC Line Cut Video
  • thefabricator03
  • thefabricator03's Avatar Topic Author
  • Visitor
  • Visitor
11 Dec 2019 07:10 - 11 Dec 2019 07:14 #152471 by thefabricator03
PlasmaC Line Cut Video was created by thefabricator03
Hi Guys,
I have made a video of PlasmaC line cut feature in Axis for those who are interested. My PowerMax was set to continuous arc mode and the gantry and z axis were controlled manually. Like a big CNC hand torch!
Here is the sheet after I have moved it, it is easy to handle these sized sections by hand.
Last edit: 11 Dec 2019 07:14 by thefabricator03.
11 Dec 2019 08:45 #152473 by rodw
Replied by rodw on topic PlasmaC Line Cut Video
I would not have thought of that so I must see if I can do the same with my machine.
I have to say that when indexing a full sheet on a small table its great to be able to sever the sheet after you have cut a table full.
  • thefabricator03
  • Visitor
  • Visitor
11 Dec 2019 11:32 #152477 by thefabricator03
Replied by thefabricator03 on topic PlasmaC Line Cut Video
Yeah its a pretty good feature.
  • thefabricator03
  • Visitor
  • Visitor
06 Feb 2020 08:12 - 06 Feb 2020 08:13 #156617 by thefabricator03
PlasmaC severing a full sheet of 5mm plate with the line cut function.
Last edit: 06 Feb 2020 08:13 by thefabricator03.
06 Feb 2020 08:26 #156618 by Clive S
Replied by Clive S on topic PlasmaC Line Cut Video
Thanks for the vid. Would you mind giving me the psi used on that sort of cut 5mm and 3mm.
  • thefabricator03
  • Visitor
  • Visitor
06 Feb 2020 08:48 #156619 by thefabricator03
I am using the RS485 interface and have the setting at 0 psi I think. That lets the machine set the air pressure.
06 Feb 2020 09:25 #156620 by rodw
Clive, for a 40-50 amp machine, try around 70-80 psi. Maybe your manual tells you what to use. From memory my machine at 40 amps my machine is meant to be set at 5.2 bar (around 75 psi)
06 Feb 2020 11:15 #156626 by Clive S
Yes I am using about 75 psi, no cutting chart with the plasma. The cutter is only 40A.
I get a clean cut on 3mm at 2.5M/min and 6mm at 450mm/min. But in the vid above. he was cutting att 1.75M/min 45A at 5mm.
I am running the cutter off a 13A socket so I might not be getting the full 40A ie. volt drop in cable and fuse.
I will try it from a dedicated 16A supply socket.
  • thefabricator03
  • Visitor
  • Visitor
06 Feb 2020 11:21 #156627 by thefabricator03
I remember reading somewhere a while ago that the larger machines will cut at better quality with lower amps due to current density,
I think the example was a 65 amp machine will cut at 40 amps better than a 40 amp rated machine cutting at 40 amps.
My machine is rated at 125 amps.
06 Feb 2020 11:38 #156630 by rodw
Clive, check your email. I sent you something which may help.
Ignore the Hypertherm specs, they cut way faster than a lot of other machines. Also you need to profile cut height by trail and error. My guess is 1.7-1.8mm cut height at 1.8-2.2m/min but you don't say what height you are using.
Time to create page: 0.149 seconds
