Configurator Error
- snowgoer540
- Thank you received: 907
04 Jan 2020 22:29 #154037
by snowgoer540
Replied by snowgoer540 on topic Configurator Error
I just updated this afternoon before I made a new axis config.
- phillc54
- Thank you received: 2100
04 Jan 2020 22:41 #154039
by phillc54
Replied by phillc54 on topic Configurator Error
Can you check the last version number in versions.html, it should be v0.87 - 2020 Jan 04
For a Buildbot install it will be:
For a Run In Place install it should be:
It definitely works here.
/usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/versions.htmlFor a Run In Place install it should be:
~/linuxcnc-dev/configs/by_machine/plasmac/versions.htmlIt definitely works here.
- snowgoer540
04 Jan 2020 22:44 #154040
by snowgoer540
Yessir that’s the version I’m on.
And the configurator is shown as updated today.
And I 4x checked I ran it from that location.
Just ran it again, same error
- phillc54
04 Jan 2020 22:57 #154041
by phillc54
Are you trying to change the mode before you select an ini file?
- snowgoer540
04 Jan 2020 22:58 #154042
by snowgoer540
Yes as it’s the top item...
- phillc54
04 Jan 2020 23:02 #154043
by phillc54
It cannot change the mode when it doesn't don't know what it is yet.
I will change it around.
- snowgoer540
04 Jan 2020 23:18 #154044
by snowgoer540
Makes perfect sense. Just a work flow thing then.
I’m good at breaking software lol
Thanks for looking into it
- phillc54
05 Jan 2020 00:04 #154049
by phillc54
I have just pushed a fix for this
08 Jan 2020 22:24 #154356
Always uses spaces, not tabs (but by all means let your editor put in multiple spaces when you press the tab key).
That way there should be no problems.
This is also a general rule for LinuxCNC code, though some files do contain the evil tabs.
Replied by andypugh on topic Configurator Error
I think its supposed to save some keystrokes for developers becasue it gets away from {} and if..end
But generally if you open a file in a different editor it breaks the indentation...
Time to create page: 0.109 seconds
