THCAD-300 and Plasmac User Guide questions
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
31 Dec 2019 04:10 - 31 Dec 2019 04:13 #153584 by snowgoer540
THCAD-300 and Plasmac User Guide questions was created by snowgoer540
Long time lurker, first time posting... First thanks to everyone who has inadvertently contributed to my success via all my lurking!
I recently converted a working gmoccapy install to Plasmac, and I am trying to get things right for my THCAD-300. It seems the Plasmac userguide specifically shows examples for the -10, and I am having some trouble getting numbers that make sense for the -300. I am in fact using F/32 as a jumper setting.
0V = 120 kHz
300V = 920.4 kHz
Under 22.1, the divider ratio for the THCAD-300 is said to be 29. I am wondering where this came from? I am guessing it is a known value from Mesa?
For 22.2, the example shown is for a 10v board. Being that mine is a 300v board, is the new formula simply Divider_Ratio/((300v_frequency-0vfrequency)/32/300)? When I plug in my numbers I get 29/((920400-120000)/32/300) = 0.347826. This leaves my display on Plasmac bouncing around between 5-8 volts. It seems like I am missing something simple here? But maybe I made incorrect assumptions when using the 10v formula for the 300v board.
Lastly, for 22.3, there's a new line since the last time I looked at the documentation:
setp hm2_7i96.0.encoder.00.filter 1
I am assuming that this just turns on the low pass filter as specified in section 4.11? Which also makes me assume that you need to add the line: setp plasmac.lowpass-frequency 100 to the HAL file as well? I am not quite sure I follow what this is useful for? Where did 100 kHz come from?
Thanks in advance for the help!
-Greg
Last edit: 31 Dec 2019 04:13 by snowgoer540.
31 Dec 2019 05:06 #153587 by tommylight
Replied by tommylight on topic THCAD-300 and Plasmac User Guide questions
You do not have a divider so do not use the 29.
That is all, as 29 multiplied by 4 to 5 you are getting will give 116 to 145.
31 Dec 2019 06:18 #153588 by rodw
I've never really agreed with the idea that you need to do some maths to configure a piece of software. I really found this confusing when I started and thats why I wrote this component that lets you enter all of the parameters and no need to do any maths
forum.linuxcnc.org/plasma-laser/32585-scalethcad-component
I still use this today and set plasmac to have a scale of 1 and an offset of zero but I have dropped the included filter.
I think your offset = 120000/32 = 3750
So your full scale = 920400/32 = 28762.5
So your range from 0v to 300v = 28762.5 - 3750 = 25012.5
So your scale (frequency count per volt) 25012.5/300 = 83.375
So enter 3750 and 83.375 in plasmac and see how you go.
The following user(s) said Thank You: taloot
  • snowgoer540
  • Moderator
  • Moderator
31 Dec 2019 16:16 #153609 by snowgoer540
Replied by snowgoer540 on topic THCAD-300 and Plasmac User Guide questions
That makes sense. Sounds like the voltage divider should actually just be 1 then.
But I am curious, why does the user guide say that it is 29?
  • snowgoer540
  • Moderator
  • Moderator
31 Dec 2019 16:20 #153611 by snowgoer540
I will definitely have to check that component out, I didnt know it existed. I thought to myself "why cant my frequencies and which THCAD I have just be part of the configuration?". I am sure there are lots of other things on the priority list though.
I think the scale is looking for a really small number though. Everything you said makes it more clear, but I'm thinking it's looking for a really small number for scale though, would it be (1/83.375) = scale (0.011994)?
So you said you dropped the filter. Why? I'm still not sure I understand what the filter is supposed to do exactly.
Lastly, someone recently brought the hypersensing to my attention. Guess I have to order another THCAD now LOL. Good work there!
31 Dec 2019 22:55 - 31 Dec 2019 23:03 #153640 by phillc54
Replied by phillc54 on topic THCAD-300 and Plasmac User Guide questions
I think you need one of these:
  1. 29/((920400−120000)/32/10) = 0.01159420289855072464
  2. 1/((920400−120000)/32/300) = 0.01199400299850074963
I don't have a THC-300, and I assumed it was in effect a THCAD-10 with internal dividers to give it a full scale of 300. (300-10)/10 = 29.
Because then it would lock PlasmaC into one hardware vendor.
No, this not the lowpass filter, it is a filter in the encoder. From memory that was recommended by PCW
Edit: forum.linuxcnc.org/27-driver-boards/3659...hcad?start=30#135396
Last edit: 31 Dec 2019 23:03 by phillc54.
  • snowgoer540
  • Moderator
  • Moderator
31 Dec 2019 23:22 #153644 by snowgoer540
I think so as well, I think option 2 makes the most sense in my mind, without really understanding the system as a whole.
Good point on locking Plasmac to one vendor, didnt think of that.
Thanks for the reply, it helps a lot!
31 Dec 2019 23:33 - 31 Dec 2019 23:42 #153646 by AgentWD40
Replied by AgentWD40 on topic THCAD-300 and Plasmac User Guide questions
I made a little calculator for this a while ago
jscalc.io/calc/NTr5QDX6WgMThBVb
[EDIT]
Reference post forum.linuxcnc.org/plasma-laser/35449-an...ent?start=910#135473
Last edit: 31 Dec 2019 23:42 by AgentWD40.
31 Dec 2019 23:40 #153650 by phillc54
If those numbers are confirmed can I put a link to that in the PlasmaC docs.
  • snowgoer540
  • Moderator
  • Moderator
31 Dec 2019 23:41 - 31 Dec 2019 23:41 #153651 by snowgoer540
AWESOME! Thank you so much!
This works out to what I ended up calculating. My machine has no voltage divider, so 1 makes sense there.
Last edit: 31 Dec 2019 23:41 by snowgoer540.
