Problems with updating to 2.9 on clean install
09 Jan 2020 06:09 #154406 by calvin.d
following the instructions here
linuxcnc.org/docs/devel/html/plasma/plas..._the_plasmac_add_ons
I did a clean install of the ISO
www.linuxcnc.org/testing-stretch-rtpreem...uspace-amd64-r13.iso
and I am trying to run
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
I am getting
calvin@PlasmaCutter:/home/calvin# apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
Executing: /tmp/apt-key-gpghome.Mo3XtW8llZ/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
gpg: keyserver receive failed: Server indicated a failure
I have tried updating the system, installing dirmngr, doing a clean install
anyone have any ideas ?
Thank You
Calvin
10 Jan 2020 01:44 #154518 by calvin.d
Replied by calvin.d on topic Problems with updating to 2.9 on clean install
also trying to directly go to
keys.gnupg.net/ and testing E0EE663E
result in no key found
keys.gnupg.net/pks/lookup?search=E0EE663...gerprint=on&op=index
10 Jan 2020 01:48 - 10 Jan 2020 01:54 #154519 by phillc54
Replied by phillc54 on topic Problems with updating to 2.9 on clean install
Oops, looks like a typo there. Try EF1B07FEE0EE663E as the key.
Edit: that was from buildbot.linuxcnc.org/ but it doesn't work here either keys.gnupg.net/pks/lookup?search=EF1B07F...gerprint=on&op=index...
Edit 2: it seems to retrieve it though:
phill@stretch ~ $ sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
[sudo] password for phill:
Executing: /tmp/apt-key-gpghome.qV9gKMMSgU/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
gpg: key EF1B07FEE0EE663E: "LinuxCNC Buildbot <nomail@linuxcnc.org>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
phill@stretch ~ $
Last edit: 10 Jan 2020 01:54 by phillc54.
10 Jan 2020 02:03 #154520 by calvin.d
just did a cut and paste of your line
calvin@PlasmaCutter:~$ sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
Executing: /tmp/apt-key-gpghome.2Atu0s4NLQ/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
This is on a clean install
C
10 Jan 2020 02:09 #154521 by phillc54
Actually the search does work with 0x prepended to E0EE663E (0xE0EE663E)
And I can retrieve the key as below:
phill@stretch ~ $ sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
Executing: /tmp/apt-key-gpghome.yiVuttUQSG/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
gpg:              unchanged: 1
phill@stretch ~ $ ^C
phill@stretch ~ $
I have no idea why it does not work for you.
Does this help? forum.linuxcnc.org/9-installing-linuxcnc...22-keyserver-failure
10 Jan 2020 02:15 #154522 by calvin.d
yep, that did it
should we update the instructions here
I was using a completely clean install based on the instruction, so other people might run into the same problem
Thank You
Calvin
10 Jan 2020 02:18 #154523 by phillc54
Are you behind a firewall, from what I have read that can cause this issue.
It seems adding :80 won't hurt anything so it should go into the docs.
The following user(s) said Thank You: calvin.d
10 Jan 2020 04:56 #154526 by calvin.d
Yep, behind a firewall
but wouldn't most machines be ?
10 Jan 2020 05:27 #154528 by phillc54
Maybe not all firewalls block port 11371. My firewall is a ISP provided router as would most I guess and it doesn't block any outgoing ports.
Time to create page: 0.348 seconds
