Questions re Plasmac
23 Jan 2020 14:34 #155547 by Clive S
Questions re Plasmac was created by Clive S
Q1. Is it possible to reduce the width of the screen by about 15mm. I have to move the screen over the click the max button to fill the screen to the correct size.
Q2. In the ini file re.
[AXIS_Z]
# set to double the value in the corresponding joint
MAX_VELOCITY = 175 Do you mean set this to double
MAX_ACCELERATION = 1500
[JOINT_1]
AXIS = Z
MAX_VELOCITY = 175 or this
STEPGEN_MAX_VEL = 200 or this
STEPGEN_MAX_ACC = 2500
As a lot of general ini files have this in it
STEPGEN_MAXVEL = 250
STEPGEN_MAXACCEL = 1875
So I am a bit confused !
Q3. I am getting an error message on startup. This bit might be better in the general forum
hm2/hm2_7i96.0: stepgen.01.maxvel is too big for current step timings & position-scale clipping to max possible
SCALE = -800
DIRSETUP = 2500
DIRHOLD = 2500
STEPLEN = 3500
STEPSPACE = 3500
23 Jan 2020 15:57 - 23 Jan 2020 15:58 #155555 by PCW
Replied by PCW on topic Questions re Plasmac
SCALE = -800
DIRSETUP = 2500
DIRHOLD = 2500
STEPLEN = 3500
STEPSPACE = 3500
The warning is saying that a maximum velocity of 200 mm/s and a scale of -800
would requite a step rate of 160 KHz (200*800) but the maximum possible step rate
with your step length and step space settings is lower than this ( 1/(3500ns +3500ns) = ~143 KHz)
Last edit: 23 Jan 2020 15:58 by PCW.
23 Jan 2020 16:29 - 23 Jan 2020 17:15 #155559 by Clive S
Replied by Clive S on topic Questions re Plasmac
Ah light bulb moment so I need to reduce the step length and spacing 2000ns as a min. ~250KHz This is using a 7i96
Thanks yet again Peter :cheer:
edit wrongly calculated math
Last edit: 23 Jan 2020 17:15 by Clive S.
23 Jan 2020 16:36 #155560 by PCW
2000+2000 would get you to 250 KHz Stepgen max velocity
(312.5 mm/sec) and a axis/joint max velocity of 250 mm/sec
(assuming your drives can do that)
23 Jan 2020 23:08 - 24 Jan 2020 00:15 #155591 by phillc54
Replied by phillc54 on topic Questions re Plasmac
If you are using Axis then you could reduce the font size in the ini file.
# the font for the Axis GUI, if not specified 'sans 10' will be used
# valid font sizes are from 9 to 15
FONT                    = sans 11
EDIT: I forgot to mention that if you use Axis and want it to start maximised then you can set that in the ini file as well:
# the window size for the Axis GUI, 0 = minimum size to suit font, 1 = maximized
MAXIMISED               = 1
[AXIS_Z]
[JOINT_1]
AXIS = Z
It is referring to the first two with the identical name.
Here are the second two from the docs (note that these are only used if you are using steppers):
STEPGEN_MAXVEL = 21.0 - Acceleration limit for the step generator. This should be 1% to 10% larger than the joint MAX_ACCELERATION. This value improves the tuning of stepgen’s "position loop". If you have added backlash compensation to an joint then this should be 1.5 to 2 times greater than MAX_ACCELERATION.
STEPGEN_MAXVEL = 1.4 - Older configuration files have a velocity limit for the step generator as well. If specified, it should also be 1% to 10% larger than the joint MAX_VELOCITY. Subsequent testing has shown that use of STEPGEN_MAXVEL does not improve the tuning of stepgen’s position loop.
So you could safely remove STEPGEN_MAXVEL and the only reason to change STEPGEN_MAXVEL would be if you used the BACKLASH setting.
Last edit: 24 Jan 2020 00:15 by phillc54. Reason: more information
Time to create page: 0.704 seconds
