contour on Pipe
- bbsr_5a
- Thank you received: 106
27 Feb 2020 12:38 #158626
by bbsr_5a
contour on Pipe was created by bbsr_5a
Hi
is it posible as of many Freesoftware opensource now got 4th axis to cut direct in plasmac to a pipe
or as of sheetcam also can do rectangulare pipe
i think of somthing like EGGBOT for sculping round oven metall sheets <200mm Diameter
as well as it can be used for rounding the pipe as to welt together 90deg Angular
- thefabricator03
- Visitor
27 Feb 2020 16:51 #158651
by thefabricator03
Replied by thefabricator03 on topic contour on Pipe
I am sure if you can post a example G-code file of what you are after Phil will have a look and say if its possible.
- bbsr_5a
27 Feb 2020 18:57 #158671
by bbsr_5a
Replied by bbsr_5a on topic contour on Pipe
thanks
things to be made like here
premierplasmacnc.com
the pipe on pipe
and the Text on pipe
while only pipe is rotating
the pipe on pipe
- Thank you received: 7478
27 Feb 2020 19:22 #158682
Replied by tommylight on topic contour on Pipe
something like this :
No need for post processor or any complicated CAD/CAM for that.
Think of it as a sheet of paper and then bend it to make a round !
- thefabricator03
- Visitor
28 Feb 2020 01:31 #158710
by thefabricator03
Tom,
How do you generate the G-code for your tube cutter?
- bbsr_5a
28 Feb 2020 07:34 #158730
by bbsr_5a
i use a simple NGC
i attached 2 NGC files as of a Hole and the Font cut
The following user(s) said Thank You: phillc54, thefabricator03
- Thank you received: 4149
28 Feb 2020 10:58 #158741
Replied by rodw on topic contour on Pipe
Depends exactly what you wan to cut, but this is a good starting point to understand how to do this (and yes it gives perfect results)
www.metalgeek.com/static/cope.pcgi
So as Tommy says, think of the tube as being a flat sheet as wide as the circumference.
When you think about it pipe cutting does not need THC action becasue the distances remain constant.
However if you want to cut SHS, you need the THC to lift the torch as it rotates around the corner.
Sheetcam has an extra cost module that unraps the rotary material but if you have a cad program, you may be able to insert a fine cut along the tube, convert to sheetmetal and cut normally.
The following user(s) said Thank You: phillc54, tommylight, thefabricator03
28 Feb 2020 11:05 #158743
I make configs for each tube diameter, so that makes it very easy to use.
Example:
Tube diameter 100mm, perimiter will be 314.15mm, draw in inkscape whatever is needed to be cut no wider than 314.15mm ( assuming X axis is rotary, allthough it is set up as linear in Linuxcnc), that is it.
No complicated math involved.
Inkscape, as usuall.Tom,
Example:
The following user(s) said Thank You: phillc54, alexandrub, thefabricator03
Time to create page: 0.219 seconds
