Configurator Syntax error.
- Thank you received: 4149
20 Mar 2020 07:49 #160836
Configurator Syntax error. was created by rodw
I just updated master branch today (compiled) and then ran configurator.py and got a syntax error.
Sorry I got called away and did not get back to this but pretty sure it was on line 992
Anyway, it was definitly on a join statment of that format and there are only 2 in the file
github.com/LinuxCNC/linuxcnc/blob/master...configurator.py#L992
I will say I have not touched my config for a few months.
if ''.join(line.split()) == 'HALFILE=plasmac.hal'Anyway, it was definitly on a join statment of that format and there are only 2 in the file
- phillc54
- Thank you received: 2100
20 Mar 2020 08:38 #160839
by phillc54
Replied by phillc54 on topic Configurator Syntax error.
Thanks Rod, I left a colon off the end.
20 Mar 2020 08:44 #160840
You did too! Thats an easy fix!
I've been battling Python on some other fronts and I find it hard! Pythonic does not mean easy!
Replied by rodw on topic Configurator Syntax error.
- phillc54
20 Mar 2020 08:49 #160841
by phillc54
I find everything hard these days...
I have pushed the fix.
Time to create page: 0.080 seconds
