Plasma cutter Startup Error
- Riggorous
05 Apr 2020 18:37 #162784
by Riggorous
Plasma cutter Startup Error was created by Riggorous
Hey guys,
New here and pretty inexperienced with Linux and CNC machines in general. I’m trying to configure PlasmaC in my home built table and am running in to some kind of startup issue.
Table specs. 4ft x4ft table, using stepper motors and a HobbyCNC Pro Chopper Board, Everlast 60s power source and a Proma 150 THC. Pretty sure the version of Linuxcnc I have right now is 2.8.x
I have a running and properly scaled configuration on the normal program all axis work and move around. I followed the PlasmaC user guide for a buildbot install of PlasmaC and configuration. When I go to start up the program I get error in my Hal file. “Pin 11 does not exist” and the program fails to start. Here is a picture of the log screen.
At a loss as to what caused this. Pin 11 is my Arc Ok input. I played around with it and it does this for any pin I set. Thanks in advance for any help.
- Thank you received: 5316
05 Apr 2020 18:47 #162786
Replied by PCW on topic Plasma cutter Startup Error
Its likely you don't have the correct pin name
I would expect the actual pin name to be something like "parport.0.pin-11-in"
Can you post your hal and ini files to the forum?
- Riggorous
05 Apr 2020 19:08 #162787
by Riggorous
Replied by Riggorous on topic Plasma cutter Startup Error
You’re absolutely correct, I re read the PlasmaC user guide and saw a note about pin name. Used Halshow and got the right pin names I needed. Seems to be working now thank you for the assist!
Time to create page: 1.823 seconds
