error or bug report on plasmac
- alexandrub
- Thank you received: 5
06 Apr 2020 13:33 #162913
by alexandrub
error or bug report on plasmac was created by alexandrub
hello,
i see something that I think is not ok in Plasmac. When i manualy jog, for example the X axis, I push the + button, and if I move the mouse up to Y selector tab with the mouse buton pushed, the x jog remain active to + moving and the y select for this moment I cant stop the X moving. For stop the moving, I need to go on the x tab and repush. In all this time the machine is moving to X+. With low speed is no problem, but at higher speed is
If is not clear what I explain, I will make a movie.
- Thank you received: 7501
06 Apr 2020 17:31 #162940
Replied by tommylight on topic error or bug report on plasmac
Axis or Gmoccapy ?
- alexandrub
06 Apr 2020 17:35 #162941
by alexandrub
Replied by alexandrub on topic error or bug report on plasmac
06 Apr 2020 17:54 - 06 Apr 2020 17:54 #162944
Just tested the 1350 build, it does not do that.
What build are you using? It is on the top of Linuxcnc screen.
Last edit: 06 Apr 2020 17:54 by tommylight. Reason: typo
- alexandrub
06 Apr 2020 18:07 #162947
by alexandrub
I use axis 2.9.0-pre0-1019-g2e0f88e
- Thank you received: 4154
06 Apr 2020 21:18 #162966
Replied by rodw on topic error or bug report on plasmac
I vaguely remember a bug report about jogging.
Is this your problem:
github.com/LinuxCNC/linuxcnc/issues/691
Time to create page: 0.083 seconds
