Arc OK High
- phillc54
- Thank you received: 2100
11 Apr 2020 23:52 #163676
by phillc54
Arc OK High was created by phillc54
@Tom
It seems you were correct, someone else was using Arc OK High.
github.com/LinuxCNC/linuxcnc/issues/721
I will restore it so what should I set the maximum to so it plays well with all HF start machines.
- Thank you received: 7501
12 Apr 2020 01:54 #163700
Replied by tommylight on topic Arc OK High
Yeah it is useful, a bit for us veterans, but it was causing some issues for newcomers.
It was a sure sign that the piercing heigh is to high for the arc to transfer or in case of firing the torch where there is no material, so it would shut it down.
From over 30 plasma sources i have dealt with, the highest open circuit voltage was 295V,usually in the 260 to 280V range, so 300 is spot on. And to have it as default.
On the other side of things, how long does it wait for an arcok signal ? Half a second should be plenty for the transfer.
- phillc54
12 Apr 2020 02:02 #163702
by phillc54
Replied by phillc54 on topic Arc OK High
Thanks Tom, I will put it back as it was.
Time to create page: 0.645 seconds
