proma sd step thc
  • getyers
  • getyers's Avatar Topic Author
  • New Member
  • New Member
17 Apr 2020 16:51 #164282 by getyers
proma sd step thc was created by getyers
how do i get the plasmac on my linuxcnc
  • Moderator
  • Moderator
17 Apr 2020 17:20 #164283 by tommylight
Replied by tommylight on topic proma sd step thc
You do not need PlasmaC for Proma SD, it has it's own THC control, it has to be wired differently, the step and dir wires must go to Proma SD and from there to the Z axis drive.
You can use PlasmaC only for probing, nothing else will work with that.
See if you can replace it with a THC150
www.proma-elektronika.com/compact-thc-150/
That one works with PlasmaC
Time to create page: 0.076 seconds
