Adding new Material in Run not working.
- CNCFred
- Thank you received: 43
21 Apr 2020 18:34 #164992
by CNCFred
Adding new Material in Run not working. was created by CNCFred
Dear all,
Today I tried to add new material for 12mm steel in Run configuration, but it doesn't add it after the name and description mask on save and OK.
Could you kindly verify or let me know what I am doing wrong?
Default and one for 5mm steel exists already so I did it already.
Thank you!
Thank you!
- phillc54
- Thank you received: 2100
21 Apr 2020 23:53 - 22 Apr 2020 01:22 #165023
by phillc54
Replied by phillc54 on topic Adding new Material in Run not working.
It work OK for me.
You will need to change all the parameters after you create it.
Edit:
After a bit of playing around I did see a couple of errors in the terminal but they shouldn't affect the creation of a new material.
You do need to use a different material number than what are in the materials file. I need to fix the error reporting for this.
Don't worry about the wierd Pierce Delay number, that is just from some other testing I am doing.
Edit:
Last edit: 22 Apr 2020 01:22 by phillc54.
The following user(s) said Thank You: CNCFred
- CNCFred
22 Apr 2020 04:58 #165042
by CNCFred
Replied by CNCFred on topic Adding new Material in Run not working.
I knew it's on me.. I guess if I use char instead of numbers in material number.. it still won't work!
Thanks Phillc54 again for dealing with my stupid question...
I am a born software tester!
- phillc54
22 Apr 2020 05:37 #165044
by phillc54
Yes, it needs to be an integer. I have fixed it so it shows those errors correctly but I haven't pushed the changes yet.I knew it's on me.. I guess if I use char instead of numbers in material number.. it still won't work!
Well without your testing I would not have seen the lack of error reporting.I am a born software tester!
The following user(s) said Thank You: CNCFred, snowgoer540
