PlasmaC Guide Voltage Divider Question for Mesa THCAD-10
- dvn4life1972
- Thank you received: 173
23 Apr 2020 20:57 #165305
by dvn4life1972
Replied by dvn4life1972 on topic PlasmaC Guide Voltage Divider Question for Mesa THCAD-10
Thanks for the reply Rod! I based my decision in large part on information I read that you have posted (for the THCAD-10). I was hoping you would chime in.
I've read some of the primer recently as well, very nice repository of information and there's quite a bit there. At this point I believe I'm very near time to test motion...fingers crossed.
Pat
Pat
- Thank you received: 4132
23 Apr 2020 21:48 #165309
Replied by rodw on topic PlasmaC Guide Voltage Divider Question for Mesa THCAD-10
The resistors are in series regardless if they are all on one of the IN terminals of the THCAD or if they are split on both sides so it does not matter. YOu always sum resistors in series
The following user(s) said Thank You: dvn4life1972
- Thank you received: 7456
31 Mar 2021 21:45 #204314
Replied by tommylight on topic PlasmaC Guide Voltage Divider Question for Mesa THCAD-10
Phill, is this the Jameson you mention sometimes ?
It sure sounds like one !
- phillc54
- Thank you received: 2100
31 Mar 2021 23:38 #204334
by phillc54
Replied by phillc54 on topic PlasmaC Guide Voltage Divider Question for Mesa THCAD-10
Haha, no I am not into spam Jameson Tom.Phill, is this the Jameson you mention sometimes ?
01 Apr 2021 00:36 #204337
- alchemy
03 Dec 2021 07:38 #228263
by alchemy
Replied by alchemy on topic PlasmaC Guide Voltage Divider Question for Mesa THCAD-10
Hi Pat
How did you get on with your voltage divider?
I'm at a similar starting stage to what you were when you posted these questions, I have a THCAD-10 card and a Razor cut 45 plasma cutter with raw voltage and an about to start putting together all my electronics. The one part I'm nervous apart is the voltage divider but it seems straightforward from what I've read here.
03 Dec 2021 07:46 #228264
Pretty sure the Razr has some outputs hidden behind a cover but I've not seen one personally.
use the formula in the thcad manual with a 200 volt full scale to determine the scaling resistor.
Than check the resistance between the output and the electrodes. If any resistance is shown, it must be included as part of the scaling resistor. Eg if you have 100k Ohms on each terminal, deduct 200 k Ohms from the scaling resistance before selecting your resistors.
- dvn4life1972
03 Dec 2021 11:53 #228277
by dvn4life1972
To be perfectly honest, I just followed what the guys here said and have been fine ever since with it. My machine didn't come with a built-in divider, as it's an older Hypertherm.
- alchemy
03 Dec 2021 19:52 #228310
by alchemy
Thanks, I'll do that. One more question, do I need to use a heavy guage of wiring from the plasma connections to the resistors and THCAD?
Time to create page: 0.087 seconds
