PlasmaC memory leak
- danilom
- Thank you received: 5
09 May 2020 19:23 #167165
by danilom
PlasmaC memory leak was created by danilom
Got one machine with Plasmac set up in October it was I think 0.097 version .as stated in ini as LAST_UPGRADE
Using it with 7i96 , updated the Linuxcnc to newest master and when starting the sim config axis plasmac version is 0.123.
Using configurator.py updated the working config, what I have now is that linuxcnc starts at around 60mb in ram and slowly grows around 0.1mb / sec , until it fills up the entire ram and locks the system.
I then started fresh with new config created with pncconf , used configurator to add plasmaC to it, and it starts and behaves the same , fills up all available RAM in half an hour.
Starting SIM config of PlasmaC Axis works flawless and does not fill up the RAM. Starting in terminal does not print any errors on screen, It looks to me that some error is happening and filling up some log file in memory, disabling Run Config Stats etc screens from loading does not help either.
- thefabricator03
- Visitor
09 May 2020 19:46 #167168
by thefabricator03
Replied by thefabricator03 on topic PlasmaC memory leak
What OS are you using?
- danilom
09 May 2020 20:03 #167169
by danilom
Replied by danilom on topic PlasmaC memory leak
Debian Stretch 64bit
- phillc54
- Thank you received: 2100
10 May 2020 00:23 #167201
by phillc54
Replied by phillc54 on topic PlasmaC memory leak
It does seem odd that a working config behaves differently than a sim config. The only difference would be the hardware drivers.
I am not at a working machine at the moment so these won't mean much but this is what I see on a sim in Mib:
If I get time this arvo I will have a look on a real machine. What hardware do you have?
axis 81.5
gladevcp 56.9
gladevcp 56.0
gladevcp 55.9
gladevcp 54.4
halui 4.2
io 4.0
linuxcnc 2.8
linuxcnc 1.9
linuxcncsvr 2.1
milltask 15.4
rtap_app 6.7If I get time this arvo I will have a look on a real machine. What hardware do you have?
- danilom
10 May 2020 00:32 #167203
by danilom
Mesa 7i96 and the computer is Fujitsu desktop with C2D E8400 cpu and 3GB ram
, tested on another computer, copied the config directory it behaves the same. Also making the same config from scratch does the same.
Could it log some message or something from 7i96?
- phillc54
10 May 2020 00:35 #167204
by phillc54
You can set a debug level in the ini file.
linuxcnc.org/docs/2.8/html/config/ini-co...l#_ini_file_sections
github.com/LinuxCNC/linuxcnc/blob/master...ml_intf/debugflags.h
- danilom
10 May 2020 00:48 - 10 May 2020 00:59 #167207
by danilom
Ok I enabled all options and only funny stuff is this
task: machine: 'plasmac' version 'unknown'
and
emcTrajSetAcceleration(999999999999999967336168804116691273849533185806555472917961779471295845921727862608739868455469056.0000) returned 0
emcTrajSetMaxAcceleration(999999999999999967336168804116691273849533185806555472917961779471295845921727862608739868455469056.0000)
there is no continual print warning or error, this almost same text is also printed with sim axis plasmac.
and
Last edit: 10 May 2020 00:59 by danilom.
- phillc54
10 May 2020 00:57 #167209
by phillc54
I get similar here...
- danilom
10 May 2020 01:06 - 10 May 2020 01:11 #167213
by danilom
New clean config is filling up much slower and cpu usage is around 3% , old config goes around 15%
maybe this ....
File "/usr/bin/gladevcp", line 349, in <module>
main()
File "/usr/bin/gladevcp", line 218, in main
handlers, mod, obj = load_handlers(opts.usermod,halcomp,builder,opts.useropts)
File "/usr/bin/gladevcp", line 120, in load_handlers
mod = __import__(basename)
File "./plasmac_stats.py", line 1
/usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/plasmac_stats.py
SyntaxError: invalid syntax
maybe this ....
main()
Last edit: 10 May 2020 01:11 by danilom.
- phillc54
10 May 2020 01:29 #167215
by phillc54
I just noticed that you are using master branch. I use 2.8. There has been a lot of recent work on master that may be the problem. When I get some time I will try master as well.
Time to create page: 0.419 seconds
