PlasmaC memory leak
- phillc54
- Thank you received: 2100
10 May 2020 01:35 #167216
by phillc54
I don't know where that line is coming from:
github.com/LinuxCNC/linuxcnc/blob/master...mac/plasmac_stats.py
Replied by phillc54 on topic PlasmaC memory leak
maybe this ....
File "/usr/bin/gladevcp", line 349, in <module>
main()
File "/usr/bin/gladevcp", line 218, in main
handlers, mod, obj = load_handlers(opts.usermod,halcomp,builder,opts.useropts)
File "/usr/bin/gladevcp", line 120, in load_handlers
mod = __import__(basename)
File "./plasmac_stats.py", line 1
/usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/plasmac_stats.py
SyntaxError: invalid syntax
- danilom
- Thank you received: 5
10 May 2020 19:23 #167297
by danilom
Replied by danilom on topic PlasmaC memory leak
Installed 2.8 and all is working fine .
- phillc54
11 May 2020 01:04 #167316
by phillc54
Thanks, I haven't had time to take a better look yet. I think I would stay away from master for a while until they sort out all the Python3 stuff.
- phillc54
23 May 2020 04:06 #168648
by phillc54
I just put in a PR for this, it was from the state tags merge into master.
github.com/LinuxCNC/linuxcnc/pull/866
- snowgoer540
- Thank you received: 907
23 May 2020 20:51 #168719
by snowgoer540
Interesting. I wonder what triggers it? I left mine (I'm on 2.9) sit for over 2 hours the other day and the memory didnt go up at all. Perhaps maybe I needed to do something though.
Replied by snowgoer540 on topic PlasmaC memory leak
- phillc54
23 May 2020 23:22 - 24 May 2020 00:55 #168743
by phillc54
The text widget that displays the active gcodes has the option of an undo/redo buffer and for some reason it was being enabled although according to the tkinter docs the default is disabled. It is updated around 6 ~ 10 times per second so each update adds the existing codes to the buffer size.
You should be able to see it, mine was about 3Mb per minute.
Last edit: 24 May 2020 00:55 by phillc54. Reason: typo
- snowgoer540
24 May 2020 15:33 #168799
by snowgoer540
Weird. I definitely dont see that. I've been meaning to go to the buildbot 2.8, it's just hard to pull the trigger when at the moment, everything is working as it should (I think, have to do some more THCAD testing).
- phillc54
24 May 2020 23:29 #168837
by phillc54
Maybe it is version dependent, I use the Stretch ISO.
If you are happy using master then that is fine, just don't be surprised if something breaks. Usually breakages are repaired reasonably quickly. If you do commercial work I would recommend 2.8.
Time to create page: 0.087 seconds
