Axis Window Layout
- phillc54
- Thank you received: 2100
15 May 2020 05:19 #167810
by phillc54
Axis Window Layout was created by phillc54
The recent state tags addition to master (2.9) which places the active g-codes on the main window instead of the MDI tab plus re-enabling the Override Limits checkbutton has increased the required height of the Axis window in landscape mode which results in it not quite fitting into a 1024x768 screen if the font size is 10.
This could be fixed by overlaying the Height Override controls and the Paused Motion controls then displaying the appropriate one. They are mutually exclusive as Height Override doesn't do anything while paused and Paused Motion only functions when paused.
I don't see any issues with doing this but I am asking if anyone has an objection.
The following user(s) said Thank You: tommylight, bbsr_5a
- bbsr_5a
- Thank you received: 106
15 May 2020 08:29 #167818
by bbsr_5a
Replied by bbsr_5a on topic Axis Window Layout
woudt this not be needed only for plasma peole and the 80+% of other mashine controller doint need it at all
- phillc54
15 May 2020 08:35 #167820
by phillc54
Replied by phillc54 on topic Axis Window Layout
This is only for the PlasmaC configuration.
- Thank you received: 7501
15 May 2020 09:16 #167825
Replied by tommylight on topic Axis Window Layout
Ok with me, although i use 24' 1920X1200 monitors, i am aware that there are still small monitor is use and for using them exclusively on a machine they are ok.
- snowgoer540
- Thank you received: 907
03 Jul 2020 23:57 #173570
by snowgoer540
Replied by snowgoer540 on topic Axis Window Layout
So, I have a weird monitor resolution, 1440x900. Is it possible to have Axis start up full screen? It's really close, but every time I open I have to click the maximize button.
- phillc54
04 Jul 2020 00:02 #173571
by phillc54
You can set it maximised here:
linuxcnc.org/docs/2.8/html/plasma/plasma...-guide.html#axis-ini
But unfortunately the calculations don't quite seem to work out correct. You could try setting the specific resolution.
- snowgoer540
04 Jul 2020 00:04 #173572
by snowgoer540
Sorry, I knew I saw it somewhere, and after combing the threads, I just asked. Never thought to double check the manual.
