PlasmaC using two P. Ports
18 May 2020 15:09 #168156 by Clive S
PlasmaC using two P. Ports was created by Clive S
Ok I have set up a machine on the bench with an old 3d printer and as gantry machine it all running fine with gantry homing and home switches on PP 0 - on PP1 is the plasma stuff breakaway, float, etc.
I did the base files first then ran the configurator the only error I got was ;-
If I comment the line out PlamaC opens fine.
I don't have a THC connected (Can you use a THC with PPorts)
18 May 2020 15:54 #168159 by PCW
Replied by PCW on topic PlasmaC using two P. Ports
You can use a standard (Proma type) THC with parallel ports
you can also use a THCAD though the voltage resolution will
depend on the base thread rate (the lower latency the better)
18 May 2020 23:22 #168205 by phillc54
Replied by phillc54 on topic PlasmaC using two P. Ports
Clive, there is a bit in the docs about that, I hope I got it right linuxcnc.org/docs/2.8/html/plasma/plasma...uide.html#mesa-thcad
  • Moderator
  • Moderator
19 May 2020 06:55 #168229 by tommylight
Replied by tommylight on topic PlasmaC using two P. Ports
I have a THCAD working with parallel port at 1/32, base thread set at 20000, it works perfectly.
If you can not get that low of latency, it can still be used by setting the divider to 1/64.
And there is no need for 2 parallel ports, if you do not need separate homing and limits.
THC 1 input,
Float 1 input
3 inputs remain for homing/limits, so plenty of options.
And please do use small relays on all inputs, saves a lot of headache with interferences.
The following user(s) said Thank You: phillc54, Clive S
25 May 2020 05:58 #168847 by CFE
Replied by CFE on topic PlasmaC using two P. Ports
Hi Clive,
We had the same problem and the gents here helped us out. What you need to do is create an encoder input to feed into the parport. I have attached our plasma-connections hal file, it shows the encoder input.
Cheers, Peter
25 May 2020 07:25 - 25 May 2020 07:26 #168848 by Clive S
Replied by Clive S on topic PlasmaC using two P. Ports
Hi Clive,
Cheers, Peter
Thanks, But on this occasion I have decided to go with a Mesa 7i96 + THC-10
Last edit: 25 May 2020 07:26 by Clive S. Reason: spelling
Time to create page: 0.482 seconds
