PlasmaC Arc getting lost
- Clive S
- Thank you received: 486
The arc ok light comes on but fails so it probe again and again. Would the air pressure need to be lowered on thinner cuts.
I have tried at 2300mm/m down to 200mm/min. I use a reed switch for the arc OK.
On a side note: nothing to do with above what THC would I require for a HF start machine and what THC for a Hypatherm 45 coupled with a 7i96. Reason I asked is the the guy wants to use a HF plasma first and then buy a 45 later. Could the THC 10 be used for both.
- phillc54
- Thank you received: 2100
On a side note: nothing to do with above what THC would I require for a HF start machine and what THC for a Hypatherm 45 coupled with a 7i96. Reason I asked is the the guy want to use a HF plasma first and then buy a 65 later. Could the THC 10 be used for both.
THCAD 10 should be fine for both, see this from PCW forum.linuxcnc.org/plasma-laser/33993-th...input-divider#105660
- Thank you received: 7488
At what current ?OK what parameters do I need to look at. I having trouble with thin 2-3mm cuts with arc lost usually. It seems to be fine on 6mm upwards.
To much current will cause the material to burn faster than the machine is travelling so it will loose the arc. Did you try faster feed rate for the thin material ?
If that does not help, might need to add another winding to the reed contact.
- Clive S
Ok Tom I lowered the Amps to 15 and it still did it. Then I had a light bulb moments and changed the pierce delay to 0.5 secs
that seems to have it cured. I will have to get some more 2mm to test further but it's looking good
- phillc54
- Clive S
Thanks Phill is it possible to edit the Name or No. on the run panel cuts. I understand you can delete them.
As I would like to reorder them ie. 2mm 6, 10mm instead of say 10mm,2mm ,6mm etc
- phillc54
From the panel you could delete each one and recreate them.
- Clive S
You can't reorder from the panel but you could edit the materials.cfg file directly, it is only a text file.
Thanks Phill I should have RTFM as I found that I could do that
- Clive S
Ok we have made a decision re the machine it is going to be the Hypatherm 45 with the port on it and the divider inside I believe
So is it still the THC 10 or THC 5
Some might argue that 5 by 50 it 250 and plasmas do give more at open circuit, but i am pretty sure THCAD can withstand that easily.
It does give better resolution.
TCAD10 will work with either, so if you do not want to risk it, just get the 10.
