2.8 or 2.9
08 Jun 2020 14:23 #170653 by KaleD
2.8 or 2.9 was created by KaleD
What are the pros and cons of running 2.8 vs 2.9 as it pertains to plasmac? Right now I'm fumbling around setting up my machine in 2.8. I want to keep things simple but I keep reading posts about reverse run in 2.9. If setting things up in 2.9 would cause greater headache for a beginner than i will just stick with 2.8.
I don't quite understand why there is a 2.8 and 2.9 while the latest stable release is 2.7. Shouldn't 2.8 be finalized before starting 2.9?
I'm curious to hear what others are running. What are the features that I'd miss in 2.9? Any links and sales pitches are appreciated.
Thanks,
  • Moderator
  • Moderator
08 Jun 2020 14:27 #170654 by tommylight
Replied by tommylight on topic 2.8 or 2.9
2.8 is the current stable release, unofficially, still waiting on something or another to make it official.
If you do not plan to fiddle and test the software side of things, use 2.8
2.9 is still in development and might have issues.
The following user(s) said Thank You: phillc54, KaleD
08 Jun 2020 14:36 #170655 by cmorley
Replied by cmorley on topic 2.8 or 2.9
2.9 is slang for master- there is no 2.9 branch yet.- or the description of the future release after 2.8.
Master is the development branch and it's likely to be unstable for a while - there was big changes added recently.
I'll have to let someone else answer about the differences relating to plasmac
08 Jun 2020 15:22 - 08 Jun 2020 23:56 #170657 by snowgoer540
Replied by snowgoer540 on topic 2.8 or 2.9
Reverse run is now standard in 2.8. No need for 2.9 master to get reverse run anymore. The easiest thing as a n00b is going to be the 2.8 buildbot versions.
Last edit: 08 Jun 2020 23:56 by snowgoer540. Reason: typo
08 Jun 2020 23:07 #170722 by phillc54
Replied by phillc54 on topic 2.8 or 2.9
FWIW I use 2.8 on my real machine.
Time to create page: 0.259 seconds
