I don't have an Arc OK
- KaleD
- Thank you received: 7
23 Jun 2020 03:41 #172414
by KaleD
I don't have an Arc OK was created by KaleD
My vintage Powermax 600 doesn't have and connections for machine cutting. I had to wire up a relay, voltage divider and probe. How has everyone obtained an Arc-OK signal? Is there a way of cheating and disabling the Arc-OK?
- phillc54
- Thank you received: 2100
23 Jun 2020 03:46 #172416
by phillc54
1 Set PlasmaC to Mode 0 and set Arc OK Low in the Config Panel to around half your expected arc voltage. You can play around with Arc OK High if you wish and that will create a window voltage. It is probably better to start with Arc OK High at its maximum and tune it later if you want.
2 Wire a reed relay into your work lead linuxcnc.org/docs/2.8/html/plasma/plasma...ide.html#reed-arc-ok
Replied by phillc54 on topic I don't have an Arc OK
You do need an Arc OK and you have two options.My vintage Powermax 600 doesn't have and connections for machine cutting. I had to wire up a relay, voltage divider and probe. How has everyone obtained an Arc-OK signal? Is there a way of cheating and disabling the Arc-OK?
- KaleD
23 Jun 2020 04:20 #172418
by KaleD
Replied by KaleD on topic I don't have an Arc OK
Will the reed relay work with all of the modes? I'm using mode 2. these are the kind of relays I have kicking around: www.amazon.ca/XCSOURCE%C2%AE-Channel-opt...l%2Caps%2C336&sr=8-4
I take it there isn't enough juice to pull it shut.
- phillc54
23 Jun 2020 04:24 #172419
by phillc54
Yes, it will work for Mode 1 and Mode 2.
You need a reed relay if you want to go the relay route, otherwise try the soft ArcOK using the Arc OK Low setting.
en.wikipedia.org/wiki/Reed_relay#:~:text...d%20from%20corrosion.
- KaleD
23 Jun 2020 04:48 #172422
by KaleD
I'm using a parallel port BOB. Do I have the option of using soft Arc OK? I thought that was for the THCAD and mesa hardware.
- phillc54
23 Jun 2020 04:54 #172423
by phillc54
You can use a Mesa THCAD with a parallel port if you have a spare input pin on the parallel port.
If you don't already have a THCAD then you would be better of finding a reed relay as it is very reliable and you don't need to read the arc voltage as your external THC will do that for you.
Doesn't your external THC have an Arc OK output?
linuxcnc.org/docs/2.8/html/plasma/plasma...uide.html#mesa-thcad
- KaleD
23 Jun 2020 05:07 #172424
by KaleD
Well... I'm using an Arduino as a THC. I edited the original code and added an Arc OK output just a minute ago but I have yet to test it.
- phillc54
23 Jun 2020 05:13 #172425
by phillc54
OK, now I understand.
If you can get the arduino to reliably read the arc voltage then you could output a frequency related to the voltage and feed it into a HAL software encoder and you could then use Mode 0 or Mode 1.
- Thank you received: 4154
23 Jun 2020 07:15 #172432
Replied by rodw on topic I don't have an Arc OK
There is another way you might be able to work with the Arduino as it can make use of the 5 volt supply.
Grab a ferrite ring and a hall affect sensor. cut a notch in the ferrite ring and glue the sensor in the gap. Insert your ground clamp lead through the ring. You should get an ArcOK signal from the hall affect sensor output.
I would attach the output to an Arduino hardware interrupt pin and go from there...
I did make one of these but my plasma cutter died before I could test it in anger..
- KaleD
23 Jun 2020 13:24 #172467
by KaleD
What frequency does the encoder use? PWM? I'm not totally sure how to ask that question. I thought there was additional hardware needed to use the encoder.
From what I read Mode 0 and Mode 1 seem to get the most out of Plasmac. If Linux CNC knows the voltage than I can adjust the THC on-screen without adjusting a set point on the THC.
If you can get the Arduino to reliably read the arc voltage then you could output a frequency related to the voltage and feed it into a HAL software encoder and you could then use Mode 0 or Mode 1.
Time to create page: 0.097 seconds
