Plamsac air scribe set up
- CBEAR
- Thank you received: 46
20 Jul 2020 16:17 #175265
by CBEAR
Replied by CBEAR on topic Plamsac air scribe set up
I'm sure that that would have caused other issues, but it still has the same error
- snowgoer540
- Thank you received: 907
20 Jul 2020 16:22 - 20 Jul 2020 18:25 #175266
by snowgoer540
Replied by snowgoer540 on topic Plamsac air scribe set up
Got him all squared away. For some reason his .ini didnt update to add the "./plasmac/" to the tool.tbl file location. It had missed the M codes location as well. I ran a test configurator on a different configuration and it worked fine, so must have been a fluke in between versions or something.
Last edit: 20 Jul 2020 18:25 by snowgoer540.
The following user(s) said Thank You: dvn4life1972
- phillc54
- Thank you received: 2100
20 Jul 2020 23:30 - 21 Jul 2020 00:05 #175278
by phillc54
EDIT: was that a plasmac update or new install?
EDIT2: I do see an issue where the configurator doesn't copy the tool.tbl for a new install. You should see a tool table not found error when starting LinuxCNC. I have fixed it but will wait for your reply before pushing any changes as more may be needed.
The USER_M_PATH works correctly for both upgrades and new install
Replied by phillc54 on topic Plamsac air scribe set up
It should put a local copy of the tool.tbl in the config directory so it shouldn't need the "./plasmac" added.Got him all squared away. For some reason his .ini didnt update to add the "./plasmac/" to the tool.tbl file location. It had missed the M codes location as well. I ran a test configurator on a different configuration and it worked fine, so must have been a fluke in between versions or something.
Last edit: 21 Jul 2020 00:05 by phillc54.
- snowgoer540
21 Jul 2020 00:29 - 21 Jul 2020 00:30 #175290
by snowgoer540
It was a new install at .140, then he upgraded to .143. I don’t think there was a tool.tbl in the config folder, just the plasmac folder underneath. It did error out, until I pointed it to the plasmac folder tool.tbl. I can have him undo it if it’s not how it should be, but it works now. The M code one was weird too, but a path change fixed it. I had the same results with a new config, the m code path was correct. I didn’t check for a tool.tbl then though as it wasn’t an issue yet.
Last edit: 21 Jul 2020 00:30 by snowgoer540.
- phillc54
21 Jul 2020 00:35 #175291
by phillc54
v0.142 fixed the USER_M_PATH issue but I didn't make it update the ini file as I hoped that no-one would be affected (I should know better)
I will push the tool table fix.
Thanks for the report.
That explains it...It was a new install at .140, then he upgraded to .143. I don’t think there was a tool.tbl in the config folder, just the plasmac folder underneath. It did error out, until I pointed it to the plasmac folder tool.tbl. I can have him undo it if it’s not how it should be, but it works now. The M code one was weird too, but a path change fixed it. I had the same results with a new config, the m code path was correct. I didn’t check for a tool.tbl then though as it wasn’t an issue yet.
- phillc54
21 Jul 2020 04:16 #175295
by phillc54
I would suggest that you make sure the tool.tbl file is in the .ini file as:this is to ensure that when he updates next it will not be overwritten.
TOOL_TABLE = tool.tblPlease Log in or Create an account to join the conversation.
- snowgoer540
21 Jul 2020 10:15 #175321
by snowgoer540
Ok, I can help him get it sorted out. So just make a copy of the tool.tbl and put it in the machine folder? Should the edits be taken out of the tool.tbl in the plasmac folder?
this is to ensure that when he updates next it will not be overwritten.TOOL_TABLE = tool.tbl
- phillc54
21 Jul 2020 10:18 #175323
by phillc54
No need, that won't affect anything.Should the edits be taken out of the tool.tbl in the plasmac folder?
- snowgoer540
21 Jul 2020 10:23 #175324
by snowgoer540
Ok, thanks Phill!
Time to create page: 0.375 seconds
