i cant open plasmac from Sample Configurations > by_machine > plasmac
- Himarc3D
- Thank you received: 49
21 Jul 2020 00:20 #175287
by Himarc3D
i cant open plasmac from Sample Configurations > by_machine > plasmac was created by Himarc3D
Hi. i have fresh install and i used the plasmac user guide to install it.
Linux linuxcnc 4.9.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) x86_64 GNU/Linux
I can from sample configurations create desktop shortcuts or open without shortcuts different configurations but when i try plasmac i get this error
im just playing around, checking GUIs to choose the one i like...i managed to install QT to play with QT GUIs (i receive message error about missing QT)
What i need to do to fix it and get plasmac simulation run? thanks
LINUXCNC - 2.8.0-pre1-6041-gb8805cef3
Error in startup script: cp: cannot copy cyclic symbolic link '/usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/axis/plasmac/axis/plasmac'
cp: cannot copy cyclic symbolic link '/usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/axis/plasmac/gmoccapy/plasmac'
while executing
"exec cp -rL [file join $chosendir $f] $copytodir"
(procedure "prompt_copy" line 147)
invoked from within
"prompt_copy $::inifile"
invoked from within
"if [ok_to_copy_config $::inifile] {
set copied_inifile [prompt_copy $::inifile]
if {$copied_inifile == ""} {
c..."
("while" body line 6)
invoked from within
"while {1} {
focus $::tree
vwait ::choice
if { $::choice == "OK" } {
set copied_in..."
(file "/usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl" line 875)im just playing around, checking GUIs to choose the one i like...i managed to install QT to play with QT GUIs (i receive message error about missing QT)
- phillc54
- Thank you received: 2100
21 Jul 2020 00:28 #175289
by phillc54
Replied by phillc54 on topic i cant open plasmac from Sample Configurations > by_machine > plasmac
I can see what the problem is, I did a recent tidy up of the directory structure and I didn't test the sim configs from a Buildbot install. I will work on it and see what I have to do.
In the meantime if you want to get started you could do a run in place install and that will work fine.
- Himarc3D
21 Jul 2020 00:40 #175292
by Himarc3D
Replied by Himarc3D on topic i cant open plasmac from Sample Configurations > by_machine > plasmac
Okay, ill try
- phillc54
22 Jul 2020 02:22 #175371
by phillc54
I have just pushed the fixes for this. When the Buildbot updates it should be good to go.
Time to create page: 0.072 seconds
